What PA active crossover can be recommended for a hi-fi aplication?
Old 17th October 2019, 03:42 PM   #31
snake69fast is offline snake69fast  Romania
Originally Posted by kipman725 View Post
The specs of the S-PRO2 modules that the STA-2000D uses are very suitable for high frequency use:
S-PRO2 - Pascal Audio
Where I might use a different amplifier would be for sub bass due to the greater power requirements.
Somebody reccommended me QSC PL 380 amplifier but I think it iis too much and I am not sure about the sound. What do you think?
Old 17th October 2019, 04:59 PM   #32
puppet is offline puppet  United States
I use EV Dx34A xo and a Rane MA6S amp (6 channel). A 3way setup would require (2) of the xo though. EV Dx38 is 3 way capable. These are older designs,balanced input/output.
Both are dead silent as far as noice through the speakers. The fan on the amp is very quiet.
Gain structure on a system like this needs to be adressed, however. DSP xos like to have input levels such that they saturate its input levels (at the xo). This may require a unit that raises consumer electronic levels to pro input levels. Aphex makes these as do others.
Old 18th October 2019, 04:54 AM   #33
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Lots of power, but not that impressive numbers for critical listening.
Things are starting to happen, work in progress: https://kaffimann.com
Old 18th October 2019, 12:54 PM   #34
Alternatives?
It is possible to use the IMG STAGELINE 2000D with only one entry and an all the power to four speakers (woofers in this case)?
Old 18th October 2019, 01:29 PM   #35
Fanatic
KaffiMann's Avatar
I just run my woofers in parallel for a 4ohm load, if you need more power you can get 2 x 1000w from the STA 2000D instead of 4 * 280w8ohm/500w4ohm. If my memory serves me correct there's a switch on back. I can take a picture when I get home.
But I do not need any more power for my woofers, have not yet managed to the the limiters to light up, even when testing with hearing protection.
Edit:
Added a picture of my den.
Edit2:
In my opinion, not much point in pushing more than 120w maybe +3db on peaks, so lets say 240 watts per driver, over that you start getting less value for your oomph, so to speak. Thermal compression, path of diminishing returns etc.
Old 18th October 2019, 07:13 PM   #36
Fanatic
KaffiMann's Avatar
Here's a picture of the extra speakons for bridged connection, as well as the impedance switches.
IMO 2kw is just barely on the sane side of regular wall sockets (and fuses), at least over time. Amplifiers that provide more actual power than this (and not silly marketing watts), require properly dimensioned grid connection.
Old 19th October 2019, 12:02 AM   #37
Spotless point of view! How I like it
OK, I'll go for the IMG's with three question for the future: better amps for the subs, better amp fort the high frequencies, better drivers. Fix will be: active crossovers, open baffle, current DAC
Old 19th October 2019, 05:13 AM   #38
H713 is offline H713  United States
My choice for an active crossover would be a BSS Soundweb London box, but even used that will set you back $500 at a minimum. Of course, you can do a whole lot more than active crossovers with that.
Some of the big old Crest amps are pretty good. I have no problem with Class D (It's a pretty cool technology), but I think some of the best linear power amps ever made were from the 1990s.
What PA active crossover can be recommended for a hi-fi aplication?Hide this!Advertise here!
Tweeter over or below recommended crossover ? adridiy Multi-Way 18 19th December 2016 01:43 AM
recommended crossover components? WaFfLe Parts 11 27th March 2015 02:15 PM
Question about Mullard EL84 Aplication note el156 Tubes / Valves 6 30th December 2014 04:37 PM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright ©1999-2019 diyAudio
