POP free codec for ADAU1701
Old 29th September 2019, 03:43 PM   #1
Baldin is offline Baldin  Denmark
Baldin's Avatar
Default POP free codec for ADAU1701
Have a miniDSP 2x4, and have also just bought a Sure Electronics DSP board with the same ADAU1701 dsp.
Both implementations have a bad pop when turning on or off. Looking at making my own implementation to build directly into active speakers.
You can implement a muting circuit with a fet on the output of each channels to compensate for this, but it will require quite some discrete components, so I was wondering if there are some better performing codec which could both boost performance and which has good muting circuits implemented already.
Maybe also being able to skip the opamp based filters on the output which at least the Sure output board seems to have could also be omitted.
I'm told that DACs like TI's PCM5102 has good muting circuits built in.
So that could be a way to go. but this will require to of these to get to the 4 outputs, and no improvements to the ADC.
But even better would be a one chip solution with bot better ADCs and 4 or more DACs.
What about Cirrus Logic's CS42516?
What would be a good and easy path in this?
Any experience, with different solutions and manufactures?
/Baldin
Old 20th October 2019, 06:07 PM   #2
Baldin's Avatar
After doing a bit of study believe there is at least 4 ways to go about this:
1. External muting circuit using either fets or bipolar transistors like the 2SD2704
2. Using a dedicated analog switching circuit which is already made for muting circuits and which accepts negative swing. A solution could be build around FSA2276.
3. Using a line driver with build in charge pump and muting circuit. A good candidate would be TI’s DRV603
4. Using a separate DAC with build in click and pop reduction. Good candidates would be TI’s PCM5100A/ PCM5101A/ PCM5102A. A good side effect would be a better overall THD performance.
My conclusion so far is that least expensive and least complex is to use a line driver with internal pop elimination. One good choice would be the NCS2632 from On Semi. It has a little lower distortion than the DRV603.
The output filters can be implemented with the line drivers and a small TCM809 can be used for supply voltage detection.
See attached schematics (2 channels shown). VOUT1 is connected to the ADAU1701 DAC output 1 etc.
Old 21st October 2019, 04:27 PM   #3
CyberPit is offline CyberPit  Japan
Baldin-San,
One more way to mute.
Using micro relay instead of muting-Tr./FETs to short the output signals.
+ No negative power supply required.
+ A break contact can mutes even in the Power Down State.
- Increase power consumption.
CyberPit
POP free codec for ADAU1701Hide this!Advertise here!
New? Sure Electronics ADAU1701 Module easp Digital Line Level 194 24th September 2019 07:47 PM
ADAU1701 DSP with RaspberryPi, how to I2S? JoeCraig PC Based 1 2nd August 2018 01:42 PM
Preamp between DSP(ADAU1701) and TPA3255 AMP KidCe Analog Line Level 4 9th July 2018 06:46 AM
ADAU1701 & Sigmastudio Red_arrow Digital Line Level 4 20th July 2009 04:34 PM
FREE FREE - Panasonic A310 DVD Player - FREE FREE Kane Williams Swap Meet 6 27th September 2008 02:35 PM
Copyright ©1999-2019 diyAudio
