Need help, Very low output from Soekris DAM 2021
Thread Tools
Old 18th September 2019, 10:33 AM   #1
daniel4381 is offline daniel4381
Default Need help, Very low output from Soekris DAM 2021
at last I could complete assembling my DAM 1021. I tested it with coaxial connection from CD player with an integrated amp. The output is very very low. I had to crank up the volume all the way to full to get some sound. There is no extra noise, but the sound very low. Also, the I2S output is not working, the indicator keep on blinking when source is i2s. I am using Amanero module and rpi3 B+, through a 2 to 1 i2s switch. I am controing the DAM by AZ lite kit. Volume of AZ lite is full and volume can be controlled by AZ lite. Do I need any driver to be installed to PC? Once I connect usb to PC there is a message in pc that driver is installed. I need your kind help to fix it, I have very limited knowledge on electronics. I dont have a pc with serial port. Can I use rs232 to USB converter to connect DAM with pc? Looking forward to getting support. Regards
  Reply to this post
Need help, Very low output from Soekris DAM 2021Hide this!Advertise here!
Thread Tools
Output stage for the Soekris R2R robertrowett Digital Line Level 122 11th February 2017 10:38 AM
Soekris DAC Asus Xonar D2X spdif output unable to signal lock rhythmsandy Digital Line Level 4 28th May 2015 03:19 AM
41hz amp6 vs. ebay 2020 and 2021 HifiBoyDenmark Parts 1 8th December 2011 08:43 PM
Coil question for TA2020, 2021(to Jan Peter?) Rick NL Class D 0 25th December 2007 01:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
