My no DAC project. FPGA and transistors.
Old 12th August 2019, 02:44 PM   #21
xx3stksm is offline xx3stksm  Japan
xx3stksm's Avatar
Hi, JohnW. Thanks a lot for your comment. We are a climber who wants to reach the summit, i.e., -120dBFS noise floor, from another route. I'm a simple person who believes in a real PCB. PCB is always my guru who teaches me a lot. When my PCB has excellent performance, it's real and correct for me even if it has some paradox with the theory.
Originally Posted by JohnW View Post
Ignoring the Digital noise sharpers, the noise of the 1bit DAC is dependent on :-
1. Jitter / Phase noise of the Clock (and isolation to this noise provided by the Relatching logic).
2. PSU noise on the DAC Array
3. Thermal noise of the components in the DAC array
4. Noise of the analogue circuit after the DAC Array.
BTW, I agree with you these are dominating factors of 1bitDSM, though I have a little bit different opinion about 1.
As to 2., I'm very interested in your approach. This is an essential point to achieve a low noise floor. Mine is a differential amplifier in saturation mode. I called it as ECL several times, but ECL may result in misunderstandings. It acts as a current switch to convert the DSM signal into an analog one without the interference from the dirty digital side. The functionality itself has nothing to do with ECL. It apparently seems fine as intended. Could you share the way you take to isolate the digital noise?
Old 12th August 2019, 05:57 PM   #22
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
So we are do things rather different, using CMOS logic as it has lower Phase Noise, and higher voltage swings.
In the attached image you can see a development PCB we are currently working on with a simple SDM discrete DAC array and FPGA modulator (Digital filtering is performed by the large XMOS which also supports MQA unfold, USB and System control etc).
This design has a galvanically isolated analogue stage, not because it helps measurements, but because in practical use isolating the USB Host ground from the Analogue system saves a whole bag of hurt with hum loops etc..
The Discrete clock stage is located between the discrete DAC arrays for shortest signal path, the SDM signals from the FPGA are resynchronized to this MASTER clock, before being fed into the DAC array.
The clock is isolated and fed back to the Digital section / FPGA / XMOS etc.
The clock circuit has an ultra low noise semi discrete regulator. Due to space constants, the DAC arrays are powered via an ES9311 Low noise regulator. If space allowed we would have preferred to use a semi discrete regulator design as used for the Master clock - but the ES9311 is not that bad, importantly in can be designed to provide "active" regulation across the whole audio B/W which is very important to avoid "capacitor sound"...
The resynchronization stages have there own regulators and LC networks to help isolation between stages.
The two transformers provided very low noise isolated supply to each channel - these are synchronized to the Audio master clock (the low Phase noise provides a low noise DC output) to prevent unwanted noise products folding back into the audio band, and despite there size they can provide 1.5A each! - infact all switching supplies in the digital section are also synchronized to the audio master clock.
The DAC array supports SDM to x512, so native DSD can be routed to the DAC array without re-modulation.
Time is my worst enemy!
Old 12th August 2019, 08:45 PM   #23
MarcelvdG is offline MarcelvdG  Netherlands
An easy assumption to make, but what is important is the frequency content (Spectrum) of the PN.
Communications / Data systems set there PN measurement corner frequency too high for audio applications - typically 12KHz or higher, making there Jitter specs. useless for audio applications - most systems have VERY poor close in phase noise due to high PLL BW, poor oscillator Q, noisy low power logic design, etc.
If you look at the PN performance of Logic family's I attached ealier you can see that ECL has worst Close-in Phase noise compared to most CMOS family's, bench testing shows LVDS is even worst.
To get a better understanding of the "ball park" Jitter performance we require with Simple Maths (There are many factors that determine the absolute jitter requirement, but such basic math gets us more or less in the correct "Decade"):-
1 bit SDM at x128 FS= 5.6448MHz = 177nS
Lets set a target of 120dB Dynamic range (1 millionth), so we need to be able to reproduce our pulse stream with a short term timing accuracy of 177nS / 1,000,000 = 177fS
177fs assumes 100% modulation, at max we have say 50%, so:-
177fS/2 = 88fS
88fS is a crude "Off the cuff" calculation and does NOT take into account many details, but its a good starting point to appreciate the Jitter requirements to achieve 120dB DR with a pure 1bit system at 128FS...
Moving average DAC array arrangements / higher SDM bits ease these PN requirements, but thats getting into the finer details...
The point is you need to forget shooting for pS short-term jitter performance, but you need to be in the low fS range...
"Short-term" means over say 5 - 10 seconds to bring the Close-in noise slope (area) down to a decent level...
What I'm trying to impress upon you is that the typical Jitter performance corner frequency spec'ed from 12KHz is useless for our discrete Audio DAC array applications - you need to be thinking about timing accuracy in a different realm to normal industry standards (In B/W and level).
Measuring Close in Phase noise with the required Dynamic range is extremely difficult and expense - when higher performance measurements are required, we have a whole RACK of computer controlled equipment to performance the task, but the system still sets the industry standard for close in Phase noise measurements (the system has been upgraded since the picture was taken):-
Heres the systems confidence test (basically the systems Noise floor):-
(Again the Mains related spuire is due to magnetic coupling of background fields into the system).
I said once before here on this forum that working with Discrete SDM DAC design is frustration but also the most educational experience a "Digital" audio designer can undertake I designed my first commercial discrete SDM DAC back in 1990/1991 (Pink Triangle Dacapo) and still to this day rely on the design fundamentals I learnt back then. I can honestly say that as a Digital audio designer, its was the most concise learning period of my whole career
If and only if the jitter only shifts the output signal, close-in noise would be the least of my worries in a sigma-delta system. The jitter then only phase-modulates the sigma-delta modulate. As long as the phase deviation is small (<< 1 rad), close-in phase noise then only causes skirts around the desired signal - which get masked quite well by the mammalian auditory system, and besides, a given amount of time variation only corresponds to a very small phase deviation when the signal frequency is low. Far-off noise, on the other hand, modulates some of the huge out-of-band quantization noise into the audio band, thereby raising the noise floor.
However, things can be more complicated depending on the exact DAC design, and phase noise may not be the correct metric. For example, suppose a clock signal with a finite rate of change goes through a buffer with a trip level that shifts up and down slowly because of the buffer's 1/f noise. The rising and falling edges will then be affected in opposite directions - when the trip level is temporarily a bit higher than average, the rising edge gets delayed a bit extra while the falling edge gets delayed a bit less. The fundamental frequency component stays essentially in place, so a phase noise measurement will hardly see any effect, but a sequential circuit that only looks at the rising edges will be affected, and anything that's sensitive to the duty cycle will be affected much more.
As an example of a DAC that would suffer a lot from low-frequency duty cycle variations, take my single-ended single-tap flip-flop and NOR gate RTZ DAC, the one that you don't like and that I only use occasionally for its simplicity when I don't care too much about noise. It has an output DC level that depends directly on the duty cycle of the clock, so low-frequency duty cycle variations directly translate into low-frequency output noise. Make a two-tap FIRDAC version of the DAC (with equal weights) and/or a balanced NOR/AND version, and the effect is solved or at least much reduced.
xx3stksm uses NRZ DACs, so he won't be sensitive to duty cycle variations to begin with. Of course NRZ has problems with differences between low-to-high and high-to-low delays, but those are cancelled to some extent by using differential signals.
Nonetheless, I'm as surprised as you are by the great results xx3stksm gets using the FPGA's output flip-flops.
Old 12th August 2019, 11:24 PM   #24
JohnW's Avatar
You say close in phase noise is masked by the signal, but I find it effects the sounds stage presentation and general presentation of Bass (I hate to use this expression, but the foot tapping ability of the system)... Phase noise is not generally heard as discrete tones (unless you have a real problem), but impacts sound stage, Macro details, sibilance on female vocals etc.
For some reason I don't fully understand - left / right sound stage is the first to collapse in the presence of Jitter - although we have a few working ideas...
The presences of correlated jitter results in a fatiguing / hard sound (an all too common vice of digital systems).
Jitter is a complex beast and cannot be summed up as a simple number, its the PN spectrum thats all important, and each DAC topology has different sensitivitys to this spectrum...
The trouble with the FPGA outputs is that they are VERY heavily correlated with the internal processing patterns - the ear is AMAZINGLY sensitive to correlated jitter... These jitter components can be just below the noise floor which time aligned averaging will expose, yet they still effect the audio reproduction, the brain is an amazing system!
Old 13th August 2019, 12:32 AM   #25
Markw4 is offline Markw4  United States
...the brain is an amazing system!
True, or potentially true. Perception seems to depend a lot on the individual and on the nature of prior listening practices. All IMHO, of course.
Old 13th August 2019, 05:41 AM   #26
The sidebands around the desired signal I was writing about are both very small and independent of the DAC topology. On the other hand, the sensitivity to low-frequency duty cycle variations and to far-off jitter are very dependent on the DAC topology.
Old 13th August 2019, 06:42 AM   #27
chris719 is offline chris719  United States
I've found no actual evidence of this need to minimize the close-in phase noise for audible purposes. Do you have any links to any testing that's been done? Just curious, if not that's fine. I'm not going to go on endlessly about it not being audible or anything.
Old 13th August 2019, 07:06 AM   #28
xx3stksm's Avatar
Thanks a lot for your pic. It's exciting to me. My impression is that you have fewer components than I imagined. It's probably because of different DAC topology you employ. Do you use RTZ? I also tried RTZ but failed. Analog FIR can't coexist with RTZ. My conclusion is NRZ is more friendly with analog FIR than RTZ at least. Next PCB I'm planning has at least 32taps, which results in many discrete components. One tap consists of three transistors and five registers. 32taps analog FIR equals to 96transistors and 160registers with 4mAx32=128mA !!! I must investigate the exact reason for the oscillation before going to next step.
BTW, I employed a differential amplifier to isolate digital noise. It was a successful result more than I expected. If I force output drivers for transistors to stay H or L, which is defined as "static zero," residual noise of DAC includes those of analog circuit but has no DSM related noise. Pic. 1(-121.3dBFS) is the best scenario I could have in my DAC topology while I actually have(dynamic zero) is -116.3dBFS. In other words, I have still 5dB headroom for improvement.
Furthermore, you must adjust the values because the residual noise of my ADC degrades the values. From pic.2, real performance in static zero is probably -124dBFS and dynamic zero is -117dBFS. So, the headroom is 7dB. It's astonishing to me. I would say digital isolation was luckily ideal.
Old 13th August 2019, 07:30 AM   #29
xx3stksm's Avatar
As long as I have experienced on my noDAC PCB, some jitter on the clock doesn't degrade the noise floor. As you wrote, NRZ is very sensitive to the difference between low to high and high to low. I need to adjust the difference with the phase adjustment function of PLL inside FPGA. But the clock with variable phase(used for high to low) has a little bit large jitter than the fixed phase clock(used for low to high). It's not impossible to use the fixed clock for high to low. I was looking forward to seeing a better result than the variable one. But I couldn't find the difference between them. So, I now use the variable phase clock for high to low. I'm sure the sensitivity to jitter depends on DAC topology. My noDAC isn't so sensitive to clock jitter. The fatal factor is phase alignment between 24taps. At least up to x128OSR, clock jitter is the 2nd in my topology.
Old 13th August 2019, 07:38 AM   #30
mterbekke is offline mterbekke  Netherlands
What if you make the measurement with a -50 or -60dB signal, I'm guessing all sorts of changes arise then.
Fewer words pls!
My no DAC project. FPGA and transistors.Hide this!Advertise here!
FPGA + WM8741 and jitter marcomar82 Digital Source 4 1st May 2013 04:51 AM
how to convert wav into i2s using a fpga dasco1632 Digital Line Level 0 12th October 2011 09:25 AM
Cs4270 &lt;-&gt; Fpga lm317t Digital Source 3 2nd January 2007 06:19 PM
Project: Surround Sound decoder on an FPGA kevpatts Digital Source 6 9th November 2004 08:17 AM
Audio project with an FPGA? gretzteam Digital Source 11 22nd March 2002 04:28 AM
Copyright ©1999-2019 diyAudio
