TDA1541A White noise one channel
Old 19th April 2019, 03:21 AM   #1
sthcoaster is offline sthcoaster  United Kingdom
Default TDA1541A White noise one channel
I'm stumped
I know this is probably a grounding issue but I can't find it.
I've triple checked my soldering etc, tried a different TDA1541A IC, tried walking a ground wire around from and to different places ...
My test rig is TDA1541A on old ARCAM Alpha board with the following:
stock DIR9001 receiver >> RyanJs I2S to PCM card >> DAC 50hz DEM as per ECDesigns >> Lampizator SRPP
It has been and is playing fine. I added the I2StoPCM card and did the 50hz DEM mod recently but am only noticing this now so it is hard for me to tell where I should rewind to because...
It is only audible when the source is off and as I usually turn that on first I have only just noticed it. When source is connected and on, the DAC is silent and music plays beautifully.
The white noise is like hard rain, it is in one channel only and it is volume dependent.
Separate issue but possibly related so may help with diagnosis >> I just completed an ACA and the amp doesn't like signal from this DAC at all. The ACA plays fine with signal from iPod etc. (though my speakers are not really sensitive enough for the ACA). I just get scratchy noise when connected to DAC even with CD player connected etc.
This DAC will play fine through my Chord amp but that must be able to handle the dodgy grounding (or DC?) differently to compensate.
Any ideas much appreciated.
Old 20th April 2019, 02:05 AM   #2
Swapped the digital outputs from the I2StoPCM card and the noise moved to the other channel so I will be looking at that board for the fault - possibly burnt a chip as I was putting it together? Or one of the pads is not soldered correctly - I will check again. and will seek help on the relevant thread
Thanks for looking
TDA1541A White noise one channelHide this!Advertise here!
Pre-Amp White Noise (Hiss) Gyzmo1012 Analog Line Level 13 22nd May 2018 09:12 PM
White noise problem stef23 Digital Source 3 30th July 2015 05:12 AM
Why white noise is always present? danny92 Analog Line Level 25 26th April 2014 04:58 PM
White Noise Generator LAJ Equipment & Tools 15 31st March 2012 12:25 PM
White noise problem Kei Solid State 4 1st February 2012 07:35 PM
Copyright ©1999-2019 diyAudio
