Replacing capacitors in soundcard Echo AudioFire with bigger caps 8
Old 14th April 2019, 07:42 PM   #21
robert2017 is offline robert2017
Banned
Also I won't wait for the caps do go dead because will take other parts and for this sound card I don't have any service manual also the board being from 2005 changing the caps is the best ideea.
Old 14th April 2019, 07:48 PM   #22
anatech is offline anatech  Canada
anatech's Avatar
Hi Robert,
I haven't heard of that term before, Vlos. Can you describe what it stands for? What cap checker do you have?
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 14th April 2019, 07:56 PM   #23
PH104 is offline PH104  United States
PH104's Avatar
New term for me too.
http://www.foxcomputer.se/Capacitor%...ss%20Vloss.pdf
Old 14th April 2019, 08:03 PM   #24
Banned
Originally Posted by anatech View Post
Hi Robert,
-Chris
Is not really 100% accurate measurement is more of an estimation based on voltage loss I guess . The higher the Vloss the higher the cap is closer to being a short circuit I guess .
Old 14th April 2019, 08:10 PM   #25
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Correct me if I'm wrong but don't electrolytics used for coupling have a longer life expectancy than you?
Old 14th April 2019, 08:12 PM   #26
Capt Grogg is offline Capt Grogg  United States
Seems backwards, what is make and model of cap checker?
Old 14th April 2019, 08:14 PM   #27
Banned
No I have a longer life expectancy up to 250 years on paper.
Old 14th April 2019, 08:14 PM   #28
anatech's Avatar
Hi PH104,
Many thanks for the link!
This really doesn't seem to be a great way to check a capacitor. The normal LCR bridge and LCR meters made by HP / Agilent / Keysight, Genrad and a few others are the only reliable way to test a capacitor. They pretty much say you can't test caps in-circuit. You can't by any method really except for maybe ESR. ESR is of limited usefulness in signal circuits, and dissipation is more accurate to indicate the health of a capacitor. Dissipation is 1/Q.
Vloss will be greatly affected by the input impedance of the meter used to measure it, and as the range changes that resistance will change also. Humidity might make a huge difference with the smaller capacitors. Measuring frequency should be in the area where the capacitor is expected to be effective.
Robert, don't waste any more money using this test. It is hopelessly inaccurate and impossible to calibrate it against the quality of a capacitor. It will mislead you for sure.
-Chris
Old 14th April 2019, 08:17 PM   #29
anatech's Avatar
Hi Capt Grogg,
I expect he is using a DVM.
-Chris
Old 14th April 2019, 08:21 PM   #30
Banned
Yes is not accurate at all to use such devices but when I swapped out those REC caps and measured the Vloss I also measured the Vloss of those replacing them .
With this tester a REC cap haing 100uf 6,3v have up to 12% Vloss so I replaced those with Nichicon FG 100uf 10v those measuring almost 0 usually between 0,3 and 0,5 Vloss on this tester for the new caps . So I think the tester in not really a joke and is pretty serious . Also the FMs and FCs did showed very low Vloss under 0,5% .
The problem with this cheap tester is with big caps not having enough power to measure those with accuracy .
Replacing capacitors in soundcard Echo AudioFire with bigger caps 8Hide this!Advertise here!
WTB (EU): 47000uF or bigger capacitors 35V+ Mario Pankov Swap Meet 3 22nd July 2017 03:04 PM
WTB: Capacitors 2200uF or bigger - 35V or more Mario Pankov Swap Meet 2 20th January 2016 04:15 PM
FS Echo Audiofire 8 dziemian Swap Meet 2 21st June 2015 09:13 PM
Replacing a wall wart with a bigger transformer ChristosP Power Supplies 1 5th April 2010 12:36 PM
Slow playback after replacing crystal on soundcard terranigma Digital Source 19 18th May 2008 01:23 PM
Copyright ©1999-2019 diyAudio
