CM6631A + ES9023 cheap board - modification...?
Old Yesterday, 12:59 PM   #71
zek is offline zek
zek's Avatar
On Win10, drivers for Xmos should not be installed.
Old Yesterday, 02:36 PM   #72
chermann is offline chermann  Austria
Originally Posted by phase View Post
The Xmos usb input chip requires a driver, if you don’t have that, it will not work on a windows computer.
yes -up to now
...no disc , no usb stick, no link , no answer
Old Yesterday, 02:52 PM   #73
back to my Cm6631A+9023 board
yesterday i got my package (yes its was at a neighbour...)
1 step
change the 3,3V regulator. i have the AP2114H 3.3. so be carefully not to get the HA version= diffeent pin layout !
according to the datasheet i see Cin and Cout is recommenden with 4,7 F ceramic...bad luck i forgot to order.
i just have 10/25V electrolytic or 4,7 tantal (for mic5205) as smallest cap at home.
original is a470/25V sanwah + i changed to a small 22F nichicon+ a wima 0,015F wima fake
i decided to put that in = Cin + Cout..the red wima fake out. on pic i mean the right low corner (old pic)...now its burn in...
1 should i use the 4,7 tantal insted????
2 is the 5m usb cable a problem and therefore i "must" have a bigger cap on the 5V in (= 3,3V regulator Cin)???
chris
Old Yesterday, 06:02 PM   #74
Default AP2114 measurments
Hi
compared to post 43 CM6631A + ES9023 cheap board - modification...?
with the 10F pin in pin out, noise of the DAC output
pic 1 pin out
pic2 pin in
pic 3 is the noise at the amps input-amp muted
looks the same..sound check is better for the ap2114 = micro details are growing, not much but fine
chris
Old Yesterday, 08:21 PM   #75
...to complete my information:
the small caps i had and i try at the moment are nichicon ukt
493-10643-1-ND
Old Yesterday, 08:27 PM   #76
phase is offline phase  United States
I think I have used the driver in the link shown here before;
Chinese AK4497 DAC dual-chip decoder board
Is the 208 version I believe, which is more universal I have found.
Old Yesterday, 08:53 PM   #77
thx.... will try it after my business trip....
Old Yesterday, 09:26 PM   #78
Ok, this is the driver I have used, and not sure now about the ones I have just posted above.
Drivers - I2S over USB Audio
CM6631A + ES9023 cheap board - modification...?Hide this!Advertise here!
ES9018K2M or ES9023 cheap boards Prosny Digital Line Level 0 27th September 2018 09:31 AM
Cheap SA9027 + ES9023 (or PCM5102) DAC, anyone try? magman Digital Line Level 64 25th July 2018 11:39 AM
Another cheap dac, SA9027 + ES9023 24BIT/96KHZ Asynchronous USB DAC impuls60 Digital Line Level 16 9th August 2015 06:32 AM
New Hifimediy ES9023 DAC with I2S board Videopac Digital Line Level 6 19th March 2014 08:05 PM
[FS] 24/192 CM6631A USB to I2S/SPDIF board thommy Swap Meet 0 15th October 2013 06:51 PM
Copyright ©1999-2019 diyAudio
