freeDSP-aurora - DSP with 8 I/Os, USB Audio, S/P-DIF, ADAT, Bluetooth and Wifi contro
Old 13th October 2019, 09:16 AM   #181
ThunderOwl is offline ThunderOwl
Hello all! I tool a quick look on freeDSP software, and i don't see "classic" channel mixing console. It is not intended to such use, or i am not seeing something obvious? Thank You!
Old 16th October 2019, 09:08 PM   #182
dspverden is offline dspverden  Germany
@Arne: Sorry for my late reply. I was very busy. I think it is the best you contact the developer of the freeUSBi via freedsp.cc. I am using a USBi from Analog. With that one SigmaStudio communicates with Aurora without trouble.
Raphael
Old 16th October 2019, 09:08 PM   #183
Originally Posted by melavi View Post
Is it possible to make a 7.1 with several active crossover on each channel?
E.g 7 x 4 + 4 channels by using 4 freeDSP-aurora DSP
Very nice project that could solve a lot of the modern DIY problems
Yes, you may have to hack the software a bit for it. But you can do that, yes.
Old 16th October 2019, 09:10 PM   #184
That is because you only see the 8channels plugin when you run auverdionControl in standalone mode. DSP plugins can define channel mixing. E.g. the HomeCinema71 does a downmix for the subwoofer.
Old 20th October 2019, 12:59 PM   #185
arneman44 is offline arneman44
At the moment im building an inteface and the sofwaire to use the aurora as a 4xsterio to 3xsterio and sub. mixer its going to take a while but im getting somewhere.
Old 20th October 2019, 01:02 PM   #186
@Raphael no problem
at the moment i havent searchd further im working on some other stuff but I'm going lend a programmer from my collage and try if it works il buy one.
Old 25th October 2019, 08:48 AM   #187
stretchneck is offline stretchneck  United Kingdom
Looking forward to the store opening on 31st October. Will linkwitz transform be possible in auverdionControl?
Old 25th October 2019, 11:50 AM   #188
rabre is offline rabre
For linkwitz transform you will need an biquad filter.
https://www.minidsp.com/applications/advanced-tools/linkwitz-transform
Old 25th October 2019, 09:30 PM   #189
Could also be done with IIR filter, this is how Sigma studio works
DSP 01: hi-fi audio signal processor | Hackaday.io
IIR filter support?
Old 25th October 2019, 09:33 PM   #190
Apparently you can :-)
freeDSP-aurora DSP by auverdion — Kickstarter
freeDSP-aurora - DSP with 8 I/Os, USB Audio, S/P-DIF, ADAT, Bluetooth and Wifi controHide this!Advertise here!
How can you stream bluetooth audio to multiple bluetooth audio amplifiers ? oxl Digital Source 4 11th July 2018 11:30 PM
Bluetooth or wifi microphone for home audio Richard_James Analogue Source 3 16th May 2017 07:40 PM
Bluetooth or WiFi davecooper PC Based 6 5th September 2016 09:31 PM
Copyright ©1999-2019 diyAudio
