TDA1543 filter capacitor calculation
Old 16th February 2019, 06:42 PM   #1
gaszto is offline gaszto  Hungary
Default TDA1543 filter capacitor calculation
Dear forum members,
Could you somebody explain please, how can I calculate the capacitance of the marked elements? It's not clearly visible what is above the capacitors. I see LPF, 49kHz (this sould be a cutoff freq., the 6dB/octave, and 1.2nF*8?)
What is the relation between its capacitance and the 680o Rout resistors? Is there any affect of the number of the DAC-IC? The capacitance should be different if I want to use 1 or 2 DAC-IC, instead of 4?
Old 16th February 2019, 08:46 PM   #2
MarcelvdG is offline MarcelvdG  Netherlands
Neglecting the de-emphasis circuit and regarding the DC blocking caps as short circuits for signal frequencies:
On each line you have four paralleled 1.2 nF capacitors, 680 ohm, 47 kohm and whatever the resistance of the circuit connected to the outputs may be. Assuming that last one to be 10 kohm (guess), the cut-off frequency is:
f = 1/(2 pi RC) = 1/(2 pi (680 ohm // 47 kohm // 10 kohm)*(4 * 1.2 nF) ~= 52782 Hz
where // means the value of the parallel connection, so R1 // R2 // R3 = 1/(1/R1 + 1/R2 + 1/R3).
Assuming infinite input impedance of the next stage:
f = 1/(2 pi RC) = 1/(2 pi (680 ohm // 47 kohm)*(4 * 1.2 nF) ~= 49466 Hz
With fewer DAC ICs, you can either keep the resistances and the capacitances on each line the same (that is, keep 4.8 nF total from each line to ground) and accept that the output signal gets smaller, or you can scale up all resistances and scale down the filter capacitances. That is, use twice the resistance and half the capacitance with two DAC chips.
Old 16th February 2019, 09:51 PM   #3
Thanks for the explanation
Old 17th February 2019, 10:34 PM   #4
One more question about the DAC. I have attached a picture from the frequency response of my DAC, how can I improve the high freqs.? At 20kHz -4dB, and 18kHz -3dB.
Old 18th February 2019, 02:15 AM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You could try using a CLC filter between your DAC and your I/V resistors. This can be tuned to give a rising response (reaching +3.2dB @ 20kHz) before rolling off to reduce the energy of images.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 18th February 2019, 10:21 AM   #6
Could you help to suggest a design tool or expressions to calculate the correct values? Sorry but I'm mechanical engineer, so I don't have a deep knowledge about the electronics, but I want to learn it
Old 18th February 2019, 10:21 AM   #7
DF96 is offline DF96  England
The drooping HF frequency response is to be expected from a NOS DAC with a crude output filter (or no output filter). Is that what you have?
Old 18th February 2019, 10:57 AM   #8
abraxalito's Avatar
Here's a starting point - you can download LTSpice (from Analog Devices) and tweak it to your heart's content.
The inductor's a Coilcraft MSS1210 and the caps I've used in such circuits have been SMT NP0 types (good stability).
Old 18th February 2019, 11:24 AM   #9
Thanks DF96, Yes I only have the RC filter, same as Kusunoki-DAC.
Old 18th February 2019, 11:25 AM   #10
Ok, I try to adjust the Ltspice model.
TDA1543 filter capacitor calculationHide this!Advertise here!
Low Filter Roll Off Calculation SyncTronX The Lounge 48 14th May 2018 08:58 PM
Asking for choke value or calculation for CLC filter Groundloops Power Supplies 5 15th September 2009 07:51 PM
DC coupling capacitor calculation luvdunhill Parts 5 18th December 2007 10:43 AM
Sime filter calculation help needed. Nordic Parts 20 15th November 2006 02:42 PM
RC filter on TDA1543 inputs ash_dac Digital Source 4 4th September 2005 06:01 PM
Copyright ©1999-2019 diyAudio
