Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
Have you considered starting with building something from a kit, then building someone else's design from the schematic, then trying to design your own circuit?
#22 |
Bret, get lost in the Elliott Sound Products site.... This is a good place to start Beginners' Guide to Electronics, Part 1 - Basic Components Explained
Woofer Assisted Wideband is the New Testament ![]() |
#23 |
How is it possible to amplify the input signal, divide it and compare the original signal, when I assume the incoming signal has changed by the time this processing has taken place? Does this all happen instantaneously, or is there a record of the incoming signal held momentarily somewhere so that it can be compared after the processing has taken place?
Negative feedback does nothing to correct the incoming signal then, only corrects the amplified signal. |
#24 |
Yes, as near as makes no difference, it's the same reason you don't fall off your bicycle
#25 |
Indeed, it only corrects the amplified signal and it only works well when the input signal varies slowly compared to the speed of the amplifier (in jargon, has a bandwidth small compared to the loop bandwidth and a rate of change small compared to the slew rate limit). Fortunately, audio signals normally meet that condition. If you were to build a 10 GHz RF amplifier, it would be very difficult to make the circuit so fast that negative feedback gave any benefit at all.
#26 |
It's hard to imagine things happening nearly simultaneously like that, but I will get used to it.
#27 |
The signal travels very fast and doesn't have far to go, don't worry about it, seriously. Imagine two railway carriages with a very tight coupling between them............
Thread | Thread Starter | Forum | Replies | Last Post |
I want to start with "liquid music" but i don't know how and where to start | ygg-it | Digital Line Level | 11 | 21st June 2018 08:45 AM |
Power soft start board / amp delay soft start board what is it ??? | thesaintxxx | Power Supplies | 5 | 18th September 2016 07:38 AM |
soft start and delay start - help please | cl1238 | Tubes / Valves | 6 | 5th January 2016 09:46 AM |
How to start? | mes1234 | Full Range | 17 | 17th February 2010 10:17 AM |
Will start my new Gainclone from Start, Need Help | samsagaz | Chip Amps | 4 | 27th May 2008 10:39 AM |
New To Site? | Need Help? |
