Ground Pours on a DAC PCB.
Old 24th December 2018, 06:32 PM   #11
MarcelvdG is offline MarcelvdG  Netherlands
To me it's an open question whether or not it's a good idea to split ground planes at all; two former colleagues of mine were very much in favour of having one and only one ground plane because they never managed to get split-ground-plane PCBs to work properly.
If you do split them, connecting them at the DAC seems to be the most logical solution. It results in the smallest detour for the return currents of signals that cross the boundary between digital and analogue.
Old 24th December 2018, 06:39 PM   #12
Markw4 is offline Markw4  United States
Agreed, one ground plane can be fine. However, its still probably a good idea to think about where ground currents are flowing. For example, if most of the digital circuitry is in one area of the circuit board, the ground return connection to its power supply probably should be located around there somewhere and not necessarily next to the analog ground return connection at the other end of the circuit board.
Old 24th December 2018, 06:45 PM   #13
MaverickPT is offline MaverickPT  Portugal
Thank you all for your replies! It has been really informative!
This leads me to my next question. Is a regular "trace connection" good enough, or should I connect the different ground traces with ferrite beads!?
Would it provide any tangible benefit!?
Thank you and merry Christmas!
Old 24th December 2018, 06:52 PM   #14
rayma is offline rayma  United States
Ground traces should always be as low impedance as possible.
Old 24th December 2018, 06:54 PM   #15
No ferrite beads! Got it!
Old 24th December 2018, 07:23 PM   #16
No beads and as short a connection as possible to the ground plane.
Old 24th December 2018, 07:44 PM   #17
Thank you!
Old 25th December 2018, 04:01 AM   #18
deusex3 is online now deusex3  Russian Federation
This is the must for the RF circuits only
[Markw4=rayma;]Agreed, one ground plane can be fine.[/Markw4]
There are may be occur additional interferences from DGND to AGND in this case
Old 25th December 2018, 05:53 AM   #19
Thorp is offline Thorp
Why it (the low GND impedance) is a must for the RF circuits only? We are talking here about 22.xxxx - 49.xxxx MHz frequencies or even higher for ESS chips.
That is why the star ground under the DAC chip is the best solution. The different currents will flow on the shortest way and the interferences between the different currents will be extremely low.
The star ground "ideea"should also be respected even there is a dedicated ground plane on a 4 layers PCB project.
I have got very good results with 2 layers PCB also, but I had to use 2 ground planes carefully inter-connected, one on each PCB side and a mirror placement of the DAC chips (it is a dual mono DAC project).
Old 25th December 2018, 06:46 AM   #20
I have mean what it is more relevant for RF , for 50 MHz this is much less important
Is it new design technique la "star ground" by Thorp ?
Ground Pours on a DAC PCB.Hide this!Advertise here!
Is it safe to do this? antenna ground tied to RCA input ground? realflow100 Analogue Source 2 11th December 2018 09:56 AM
Copper Pours Ripcord Construction Tips 13 15th February 2014 11:36 PM
Trimming polygon pours in Eagle, help needed SunRa Software Tools 2 27th March 2011 04:07 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright ©1999-2019 diyAudio
