Opamps for PCM1794 I/V conversion?
Old 30th June 2020, 04:49 PM   #71
guentir is offline guentir  Austria
Originally Posted by Mark Tillotson View Post
So the desired opamp performance for I/V conversion is < 4pA/√Hz and < 3nV/√Hz, and < 0.0004% THD. LM4562 might be good bet here.
You´re right, in this application, the LM4562 & NE5532/4A is on par in terms of THD / Noise and (very) hard to beat.
To my surprise, the OPA1656 works very well in this i/v position, betters the 2 above about 2-3 dBFS.
cheers,
guenther
Old 1st July 2020, 06:33 AM   #72
samoloko is offline samoloko  Bulgaria
thank you for this application
Originally Posted by PaulFrost View Post
Very cool board!
Here is a little tech note I wrote about the output stage of the PCM1794A. This mostly focuses on the gain balancing from the first and second stage. Another thing to consider is that you do not necessarily need symmetrical supplies for the first stage. The inputs stay at the virtual ground, so that stage does not really need a high voltage positive supply.
http://www.ti.com/lit/an/sbaa333/sbaa333.pdf
Opamps for PCM1794 I/V conversion?Hide this!Advertise here!
Which dual opamps should I try for I/V conversion? homemade Digital Source 29 5th November 2016 06:10 AM
Decompensated opamp oscillating? Fried opamps? PCM1794 IV Stage zxgravediggerxz Digital Line Level 1 9th October 2013 03:40 PM
my DAC PCM1794 v9688 Digital Line Level 1 16th September 2013 10:06 AM
AF filter using opamps - substitution of opamps neazoi Solid State 19 5th October 2011 04:01 PM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
