Multichannel DSD256?
Old 12th April 2019, 07:50 AM   #41
HpW is offline HpW
Originally Posted by maxidcx View Post
Also the lack of a slave mode for AKM type of synchronous DACs with local crystal is a bad thing...
May an old solution given from Jens (RTX) using a digital solution and feeding the master clock to the USBStreamer.
Also, one man should check (if needed), whether they REALLY support now digital 192Khz SPDIF in, while on the USBStreamer the digital input with 192Khz SR of simple do not trigger, while done as a SW PLL.
hp
FFT Analyzer & Generator at www.hpw-works.com
Old 12th April 2019, 09:46 AM   #42
JensH is offline JensH  Denmark
Yes, modifying it in the same way as the USBStreamer might be possible.
It looks like they use one crystal oscillator (24 MHz, the small black rectangle) feeding pin 125 of the XMOS device.
The 10-pin IC could perhaps be a PLL (like on the USBStreamer). So it might be possible to identify the MCLK and replace it with an externally generated MCLK. But I don't have an MCHStreamer, so I cannot be completely sure.
Perhaps someone with an MCHStreamer could identify the IC's and the routing?
The XMOS IC is similar to the one I used on the Audio Analyzer, so the PCB floor plan looks familiar.
Old 21st July 2019, 04:21 PM   #43
janosch simon is offline janosch simon  Germany
any news guys?
Multichannel DSD256?Hide this!Advertise here!
DSD256 not playing - BBB Hermes, Cronus, B3SE HeadSh0T Twisted Pear 0 8th February 2017 04:04 AM
PCM384/DSD256 Capable USB DAC with Tube Buffer nautibuoy Swap Meet 5 1st August 2016 02:14 PM
Multichannel DSP mirrijakys Parts 3 9th April 2016 11:54 PM
multichannel dac via i2s wischem Digital Source 2 10th June 2014 09:50 AM
Multichannel DAC cniemira Digital Source 0 8th December 2002 04:24 PM
Copyright ©1999-2019 diyAudio
