Works Sure/Wondom Programmer with freeDSP Classic SMD B?
Hi everyone! I finally will take the digital step in crossovers and all that stuff and wondering if the Sure/Wondom 1701 programmer will work with freeDSP Classic SMD B. For starting, if I could avoid building some item, more chances to focus on hard task for me (programming the ADAU1701).
Thx for open a new world to old people!!!
This is the programmer
Do you have the Sure ICP1 programmer? They had a couple of different programmers. The ICP1 has a 6 pin cable that matches the Sure boards while the freeDSP uses a 10 pin cable. In that case you'll need a 6 to 10 pin conversion cable. Here's a diagram of the one I made.
  • USBi to Sure 6-pin no switches.pdf
