USB output mixer interface
Hi all
I’m experimenting with live a musical project which features 2 keyboard amps, a bass amp and a sub, all coming from a single laptop. What I’d like to try and build is a custom interface that will appear as 4 assignable outputs on the computer, and have 4 physical faders that will help me quickly adjust the levels on stage while I’m playing. A midi in would also be nice :D
So ideally:
- usb input which will produce 4 assignable outputs in DAW
- 4 jack outputs, each with a fader
- midi in
- master fader that controls the output of all 4 channels
After researching on here and other places I came across the miniDSP/freeDSP/ADAU1701 boards but I’m still unsure if these would be the best choice and what other components I’ll need. Also how I’d go about creating the custom drivers I’d need to get the 4 outputs appearing on my DAW.
If anyone could point me in the direction of similar projects or give any advice it would be much appreciated!
Cheers
