Please help me with my homework TDA1307+TDA1547
What are you trying to do?
The 1307 does not send data to the 1547 via I2S, it is sent by separate left & right bitstreams and a clock.
If you want to change the 1307's input mode, you need to write to its internal registers using an external microcontroller connected to pins 38,39 & 42. The default setting for input mode is I2S upto 20bits.
Thanks Reply
Yes, I have to enter I2S to 1307
1307 default is I2S mode, then I don't have to do anything. Directly introduce I2S signal into 1307.
