16x Digital interpolation filter - drive PCM56, PCM58, AD1865 and so on up to 768 kHz
Old 16th April 2019, 10:03 AM   #81
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
1st post: "The price for a fully assembled and ready to use board will be 150 EUR."
Old 16th April 2019, 11:03 AM   #82
3lite is offline 3lite  Poland
I cannot promise it will work though. It purely depends on the available clocks. However, as mentioned within first post following lower frequency clocks (usually BCLK which can be connected to MCLK input of my digital filter) can work as a master clock (MCLK) signal:
6.144 MHz
5.6448 MHz
4.608 MHz *
4.2336 MHz *
3.072 MHz
2.8224 MHz
1.536 MHz
1.4112 MHz
Old 16th April 2019, 11:52 AM   #83
dreamth is online now dreamth  Romania
thank you!
Old 19th April 2019, 06:50 AM   #84
Hans Polak is offline Hans Polak  Netherlands
6.144 MHz
5.6448 MHz
4.608 MHz *
4.2336 MHz *
3.072 MHz
2.8224 MHz
1.536 MHz
1.4112 MHz
Extremely impressive what you have achieved.
What could possibly be the reason that a long FIR filter sounds better than a shorter version as usually found in Dacís
Looking at specís from Dacís, they all have very low pass band ripple, very high stop band suppression, linear phase and low THD.
But all (digital) filters suffer from time smearing, the sharper the transition from pass to stop, the more ďsmearingĒ. No filter can escape these physical laws.
So there must be something else why longer filters are sounding better, any idea why ?
Hans
Old 19th April 2019, 07:55 AM   #85
chris719 is online now chris719  United States
What could possibly be the reason that a long FIR filter sounds better than a shorter version as usually found in Dac’s
Looking at spec’s from Dac’s, they all have very low pass band ripple, very high stop band suppression, linear phase and low THD.
But all (digital) filters suffer from time smearing, the sharper the transition from pass to stop, the more “smearing”. No filter can escape these physical laws.
Hans
Psychology?
A typical synchronous interpolation filter like this, being LTI, doesn't create harmonic distortion. You don't see that specified on filters like this.
This "time smearing" isn't an artifact, so I really dislike using that term for it. An ideal reconstruction filter will have this "time smearing", but it will reconstruct the original waveform perfectly. It's not actually time smearing, because we don't listen to impulses.
It's often possible to improve on the built-in filters because they typically allow for some aliasing in the transition band in order to meet the marketing requirement of a 20 kHz passband with the number of taps they are afforded.
This is a really nice effort. I'd definitely get one if I were using one of the DACs it's designed to interface with.
Old 19th April 2019, 09:50 AM   #86
Originally Posted by chris719 View Post
Psychology?
I donít get this aliasing, I see no technical reason for that, but I agree that the signal might become corrupted by this filter process in some way and that longer filters may produce lesser corruption anomalies.
Hans
Old 19th April 2019, 10:01 AM   #87
I don’t get this aliasing, I see no technical reason for that, but I agree that the signal might become corrupted by this filter process in some way and that longer filters may produce lesser corruption anomalies.
Hans
Uh... The filter must be in the stopband by the Nyquist frequency in order to avoid any aliasing.
Most DACs have built in filters which have specs like Passband: 0.454*Fs, Stopband: 0.546*Fs (taken from PCM1792A datasheet).
This means the filter is not fully into the stopband until 24.078 kHz when Fs = 44.1 kHz. This is > Fs/2. The passband is conveniently 20.02 kHz. This is chosen so the marketing department doesn't have to explain why their DAC isn't flat to 20 kHz. The filter would have to be longer in order to narrow the width of the transition band.
There's no need to talk about ambiguous corruption, because it's all quantifiable. Fortunately, 3lite has produced a nice set of filters here.
Old 19th April 2019, 10:40 AM   #88
Luke is offline Luke  New Zealand
16x Digital interpolation filter - drive PCM56, PCM58, AD1865 and so on up to 768 kHz Send a message via AIM to Luke
Hi 3Lite, my intention is to run Ian's I2S to PCM after this as I am building balanced dac. Do you foresee any issues with this configuration?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 19th April 2019, 12:03 PM   #89
Nyquist can stay at home, we are discussing filtering of an upsampled signal. No aliasing or backfolding takes place.
And in case the digital filter leaves some residue from 22kHz to 24kHz, this will simply appear in the analogue signal after d/a conversion still residing at 22kHz to 24kHz.
I don't think anyone will notice that.
Hans
Old 19th April 2019, 03:48 PM   #90
Nevermind
16x Digital interpolation filter - drive PCM56, PCM58, AD1865 and so on up to 768 kHzHide this!Advertise here!
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board iancanada Digital Line Level 938 18th March 2019 10:45 PM
Digital Noise at Low Volume Level (AD1865) Nikon1975 Digital Line Level 2 20th December 2015 03:46 PM
XMOS direct drive PCM1704, PCM56, PCM63 and others for NOS mode or PC oversampling joro_s Digital Line Level 28 11th March 2014 04:50 PM
Audio Note UK DAC 4.1 digital PCB AD1865 bbakota2000 Swap Meet 0 13th October 2012 08:54 PM
WTB: PCM58 and PCM 64 simonov Swap Meet 0 30th November 2008 08:50 AM
Copyright ©1999-2019 diyAudio
