Moonshadow XMOS DAC - No I2S Output
Old 28th July 2018, 08:53 PM   #1
snoopy33 is offline snoopy33  Ajman
Default Moonshadow XMOS DAC - No I2S Output
Does anyone have one of these boards working?
XMOS数字界面板,CPLD波形重整技术-月影科技
They are popular on aliexpress.
I'm using Linux, so no drivers required, and I'm feeding the I2S lines into a ES9028Q2M board which I've verified is working correctly.
And... no output.
Did a quick test of the output pins and have:
Data 3.28v
BCK 1.64v
LRCK 1.64v
MCK 1.64v
Which appears to be correct. A bit stumped.
Aliexpress seller was helpful until the protection ran out, which I didn't catch, then unsurprisingly silent.
Andrew
Old 29th July 2018, 11:28 AM   #2
percival007 is offline percival007  England
Not familiar with Linux, so first things first, are you sure your USB (?) source is 'talking' to the PCB?
Are they talking the same Language? i2S can have a few 'dialects' ! Left Justified etc etc.
Have you a 'scope? Can you actually see some Data and Clocks on the i2S Lines? Those are just DC Voltages you quote which could be there when powered even with no Signal.
P.
Old 29th July 2018, 11:36 AM   #3
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
If those voltages are what you got from a DVM then the 'Data' voltage looks suspicious (too high), the others are fine (as they're clocks at 50% duty cycle).
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 29th July 2018, 11:39 AM   #4
Hi, I used a PCM2704 based converter to ensure the DAC (a ES9028Q2M) is working, so the issue is with the XMOS USB-I2S.
For the XMOS, it's recognised fine. I've tested on Linux and Windows with same result so don't think it's a driver issue.
I note the 1.64V lines are the same as the output of the PCM2704 (1.64V is probably the digital on/off averaged by the multimeter). Whether they're talking the same I2S "variant" I'm unsure, but I'd like to hope so.
I don't have a scope but I do have a data recorder good for 20MHz. If I2S lines are less than this I can try capturing. Worth a shot!
Old 29th July 2018, 11:41 AM   #5
Thanks Abraxalito, I agree it initially raised an eye-brow. I've checked and it's not shorted with the 3.3V line. I'll get the data recorder onto it first.
Old 29th July 2018, 11:53 AM   #6
Results:
Data is 0V when not playing (my error earlier). Once playing I can see signal. Looks clean
BCK is a square wave signal with some roll on/off. Not the cleanest.
LRCK is a similar square wave but much cleaner than BCK.
So indeed looks like a compatibility issue.
Old 29th July 2018, 12:04 PM   #7
Default Pictures
Pictures attached
Old 29th July 2018, 12:09 PM   #8
abraxalito's Avatar
Those three signal plots look reasonable for I2S running at 2.8MHz BCK (so 32 bits per channel).
Old 29th July 2018, 01:50 PM   #9
Thanks.
I've tried WIndows 7, 10 and Linux now, same on all.
It looks to me the I2S signal is malformed in some way.
Old 29th July 2018, 03:17 PM   #10
canvas is offline canvas  Taiwan
It should work unless DOA. I've seen people using this USB bridge and claimed having better performance than regular XMOS.
Moonshadow XMOS DAC - No I2S OutputHide this!Advertise here!
!!! Xmos Problem !!! Dual AK4495S AK4495SEQ AK4118 DAC decoder XMOS USB w/LME49990 G D Digital Line Level 58 10th November 2017 07:42 PM
FS: XMOS and DAC boards ultrafi Swap Meet 4 11th January 2017 12:43 PM
Ok Experts! How to program xmos i2s for 768k input/output? errmoo Digital Line Level 7 10th June 2016 01:32 PM
Xmos usb to i2s pcb for sale butler Swap Meet 1 26th April 2015 02:02 AM
Problem with XMOS output triode_al Digital Source 2 17th October 2013 08:54 AM
