lingDAC - cost effective RBCD multibit DAC design
Old 29th March 2020, 06:57 AM   #731
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
At the start of my DAC journey I really didn't have any reference other than comparing a modded board to the original. I did find mods made a surprising amount of difference, mainly because the layout initially was so bad (the designer had ignored DS recommendations). I played around a lot with opamp I/V stages and filtering but eventually migrated to playing with TDA1543s which initially sounded rather dull to me in comparison. Is that what you meant by 'lacked detail' ?
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 29th March 2020, 07:55 PM   #732
Bartb is offline Bartb  Slovenia
Originally Posted by abraxalito View Post
You'll then need at the very least a headphone amp to create the simplest system - I am working on a design for that or you could use the SEbuff from lingDAC which is earlier in the thread.
Hello Richard,
(with reference to the above quote from post #709), would the SEbuff require modifictions in this case?
And if one's system comprises a preamplifier + amplifier, is the SEbuff still necessary to interface the PhiDAC/LingDAC (to the system)?
Old 29th March 2020, 09:08 PM   #733
GORDMUS68 is online now GORDMUS68  South Africa
Hello abraxilito,
I recall the lingdac v2 design had space for non fit capacitors with regard to compensating variation of inductors and their effects to frequency response. The difficulty to non technical eventually led to the abandonment of the lingdac, however those with understanding can still progress.
The lack of base had also arisen from some in the lingdac, although I canít say that I found/find that (simple battery power). The power supply improvement from subsequent development has led to better low frequency.
Is there any way to make improvements to the existing lingdac power supply? Or is it best just to move along with the new progress?
Old Yesterday, 02:02 AM   #734
abraxalito's Avatar
No mods required to the SEbuff but it runs at 7V so will need a regulator to reduce the 12V supplied to the DAC. Alternatively if the headphones being driven were higher impedance ones (say HD650 300R) then the SEbuff could be driven direct from 12V and the bias current reduced to maintain the same dissipation in the FETs.
No need for SEbuff if the load to be driven is a normal line-level one (above 5k say). The buffer's only needed to drive headphones i.e. high current loads.
Old Yesterday, 02:16 AM   #735
abraxalito's Avatar
Running on batteries - low impedance LiFePO4 would be ideal - wasn't the configuration when I remarked on the bass weakness of lingDAC. Rather I was running with the stock PSU board which has a few switched-cap voltage doublers and discrete series regs. Adding extra caps on the supply to the filter-I/V board improved matters in the bass with that set-up.
Run the filter-I/V board on the lowest impedance supply you can get, either with low ESR batteries or lots and lots of caps. I think I ran with over 100,000uF in my improved set-up - I discovered that my substantial supply of Panasonic 15,000uF 6.3V caps still worked fine at 9V
Old Yesterday, 03:38 AM   #736
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Yes dull is a fair comparison to make against the AD1955.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old Yesterday, 04:05 AM   #737
abraxalito's Avatar
I eventually discovered that relative 'dullness' was more true to the source than the 'detail' which I had become accustomed to in AD1955. That finding was made when I started playing with low-pass filtering on the output of a DAC - by increasing the number of ferrite beads I used between DAC and I/V stage I was able to reduce the amount of 'detail' I got. Now I see 'detail' as an artifact which indicates something wrong in the DAC.
Of course some of the 'dullness' comes as a result of NOS droop so that needs fixing up.
Old Yesterday, 07:55 AM   #738
that's an interesting observation regarding detail being filtered out. I have a buffalo dac and a TDA1541 OS dac (pedja) and they both sound better to me. than tda1543 or AD1955, my biggest problem is my speakers are not good as the rest of my audio (kef Q900). I want to upgrade them at some stage, but they aren't too bad either.
Old Yesterday, 12:30 PM   #739
Much Appreciated - noted
Old Yesterday, 06:26 PM   #740
Ok thanks !
lingDAC - cost effective RBCD multibit DAC designHide this!Advertise here!
Extremely cost-effective and professional PCB Layout design service Kevmeister Vendor's Bazaar 0 30th June 2013 05:27 AM
Most cost effective way to store cd's jerryo Digital Source 9 31st December 2009 09:13 AM
Cost-effective audio cap relycap Vendor's Bazaar 0 27th September 2009 03:56 PM
Most cost effective active set up ? jerryo Class D 0 20th November 2007 03:56 PM
Cost effective upgrades Pan Solid State 4 9th April 2003 12:09 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
