lingDAC - cost effective RBCD multibit DAC design
Old 14th July 2018, 01:41 PM   #21
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
In my estimation TDA1387 is more true to the source than TDA1543. The bipolar chip is very pleasant indeed to listen to with the lingDAC I/V and buffer stage after it, but somehow its just a bit romanticized when compared to the 1387 - a little softer and subtly coloured.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 14th July 2018, 01:54 PM   #22
schillg11 is offline schillg11  Germany
hi abraxalito,
where to source the TDA1387T? Are there any trustworthy sources to buy this part?
BR
GŁnni
PS: Group buy or Gerbers available?
Old 14th July 2018, 02:05 PM   #23
abraxalito's Avatar
I sourced all my TDA1387 on Taobao, I have no documented chain of custody for them but I believe them to be 'pulls' from old 'Soundblaster' PC audio cards. They're obviously not new chips. Seeing they're so cheap (nowadays around 35 to the USD) I've never worried about whether they're 'legitimate' or not. Having used a few hundred of these parts during my prototyping years I've not found one yet which has sounded bad though I do note the DS shows the worst-case SNR can be just 86dB.
Gerbers I will make available after I've made the schematics more presentable (and corrected any errors) but I am not interested in organizing a group buy myself. Should anyone else wish to get involved in that (which seems to me to be rather a thankless task) I'll support them to the extent I am able. If anyone is interested in acquiring a finished DAC you're free to PM me.
I've attached a picture of one of the early incarnations of lingDAC - its a USB-fed DAC-AMP driving low impedance headphones direct up to 100mW or so. Three of the PCBs (DAC, I/V-filter, SE buffer) are in the plexiglass tower. In the wooden base are a USB-I2S interface (not my design, sourced from Taobao) and a power supply.
Old 14th July 2018, 03:16 PM   #24
thanks abraxalito,
i have also an 8xTDA1387 as replacement for a TDA1541aA in my Marantz CD583 in use. Worked without any modifications. These chips were also pulled and i got them for €6 (8Pieces).
Thnx for publishing the gerbers, when all debugging is done.
BR
GŁnni
Old 14th July 2018, 04:13 PM   #25
Bartb is offline Bartb  Slovenia
Hello Abraxalito,
the lingDAC project you are presenting here is for driving headphones if I understand correctly? How much modification (if any) would be required for interfacing with a preamplifier/amplifier ?
Thanks B.
Old 15th July 2018, 01:36 AM   #26
abraxalito's Avatar
Hi Bart
In reality there's no need to modify anything to drive a preamp or poweramp but in practice there may be a small improvement in SQ by replacing the electrolytic output capacitors for some film/foil ones of smaller value (say 6.8-10uF) and increasing the output cap biassing resistors by a factor of 20 (to 100k).
Old 15th July 2018, 11:03 AM   #27
Hi Bart
Ok! thank you for the explanation
Old 15th July 2018, 12:50 PM   #28
kokoriantz is offline kokoriantz  Lebanon
Tda1387 has only 30db ripple rejection ratio vs 50db for tda1543 . The Vref being 1/6th of Vcc , did you try to impose externally a fixed low impedance potential on Vref ?
Old 15th July 2018, 01:14 PM   #29
abraxalito's Avatar
No - I have thought about that but not gone on to implement any ideas I had, I'd always assumed that any active driving of pin7 would potentially increase output noise. A few years ago I was advocating a few thousand uF to be put on pin7, these days I use nothing at all as I hear no improvement when I do add some amount of capacitance.
Old 17th July 2018, 06:54 AM   #30
In 2014 you were in love affair with tda1545A . What happened that you switched to tda1387 ? And why not 1311?
lingDAC - cost effective RBCD multibit DAC designHide this!Advertise here!
Extremely cost-effective and professional PCB Layout design service Kevmeister Vendor's Bazaar 0 30th June 2013 05:27 AM
Most cost effective way to store cd's jerryo Digital Source 9 31st December 2009 09:13 AM
Cost-effective audio cap relycap Vendor's Bazaar 0 27th September 2009 03:56 PM
Most cost effective active set up ? jerryo Class D 0 20th November 2007 03:56 PM
Cost effective upgrades Pan Solid State 4 9th April 2003 12:09 AM
Copyright ©1999-2019 diyAudio
