Airplay 2 receiver
Airplay 2 receiver
Old 18th March 2018, 11:07 PM   #1
surfstu is offline surfstu  United Kingdom
Default Airplay 2 receiver
I know everyone is in the dark regarding airplay 2 - but I'm trying to figure a solution and am thinking that I could use an apple TV (new generation) which I'm assured will be a device that i can stream airplay 2 to.
It does not have any optical out (thanks apple) but I wanted peoples thoughts on converting the HDMI output to audio.
I've seen many boxes that promise to convert HDMI to audio but I'm unsure if they will be any good?
Any ideas?
Stuart
Old 19th March 2018, 01:46 AM   #2
vizion is offline vizion  United States
Not Airplay 2 ready but you can pick up a StreamUnlimited Airplay BBB cape with i2s output...that's what I currently have coupled to a NOS DAC
Old 19th March 2018, 10:53 AM   #3
Thanks vizion.
I should have mentioned that I've built similar systems for airplay, currently using a raspberry pi which has shairport allowing airplay streaming.
I now need airplay 2 and apple is dragging it's feet with its arrival and we are probably a long way from having access to airplay 2 in the diy community.
This is why I thought about HDMI audio but I'm unclear as whether these HDMI converters will give me a good stereo output for audio
Stu
Old 23rd August 2018, 03:49 AM   #4
Nelwar is offline Nelwar
Any luck on your airplay 2 project. I to have built a raspberry pi with shairport but looking for something similar with AirPlay 2 support
Thanks in advance.
Old 14th September 2018, 08:20 PM   #5
mstang1988 is offline mstang1988  United States
Originally Posted by surfstu View Post
Thanks vizion.
Stu
There are HDMI splitters that should do coaxial/optical output on PCM sources if I remember right. This would let you use whatever DAC you wanted that supports optical input.
Airplay 2 receiverHide this!Advertise here!
Class D and AirPlay jmhitchcock Class D 6 11th August 2016 10:47 PM
DIY Airplay/DLNA denny9167 Digital Source 0 15th December 2013 07:19 PM
Sourcing parts for first build with AirPlay OliverTwist Parts 0 10th March 2013 04:23 AM
DIY AirPlay Board? Kalleg PC Based 8 16th February 2013 07:53 PM
Airplay box design, need help with parts Njit Parts 0 27th January 2013 10:44 PM
