Hello,
I'm looking for inexpensive usb dac. Found this
1 SA9227 + PCM5102A
SA9227 + PCM5102A 32BIT / 384KHZ USB DAC/HIFI Asynchronous Decoder-in Smart Remote Control from Consumer Electronics on Aliexpress.com | Alibaba Group
2 SA9027 + ES9023
SA9027 + ES9023 24BIT/96KHZ asynchronous USB DAC / HIFI Sound Card Decoder board | eBay
3 ES9018MK2 + SA9023
Aiyima 2017 ES9018MK2+SA9023 Decode Board USB DAC Stereo Digital Audio DAC Decoding /COAXIAL OUT External Sound Card 32 bit -in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
4 CM6631A Digital interface
2017 CM6631A Digital interface 32 / 24Bit 192K Sound Card USB to I2S / SPDIF Coaxial Output Support Connect Decoder Upgrade DAC-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
5 6X TDA1543 Parallel
HIFI 6X TDA1543 Parallel Fever Audio Decoder DAC PC USB External Sound Card | eBay
Any advice?
Thank you
1 SA9227 + PCM5102A
2 SA9027 + ES9023
Any advice?
Thank you
It may be out of your budget, but I would recommend building a Soekris DAM1021 R2R DAC. This DAC sounds spectacular! You can combine it with USB to I2S convertor like an Amanero or one from DIYHINK.
See:
Soekris Engineering ApS, Products dam1021
There are quite some good threads on it on Diyaudio as well...
See:
The ODAC comes to mind, of course. Bare boards are at USD99.
Otherwise check HiFimeDIY Store they have som interesting products.
I have a couple of these in the link.
Work and sound very good and ebay cheapies.
ELE EL-D01 MINI HIFI USB PCM2704 DAC BOARD CARD + ELNA Capacitor New | eBay
