Modding an HiFimeDIY ES9018k2M DAC
Bought one of these recently:
Hifime SPDIF Optical DAC (ES9018K2M)
I hooked it on a TPS7A4700 Power supply, the Dac is dead silent.
But compared to any other Dac or player I own the 9018DAC misses warmth, i.e presence in the lower mids.
The combination in this DAC with Sabre ES9018k2M and 9601 headphone/line out driver seems to be very common.
Any way to mod this DAC to get back some warmth?
TNT
Joined 2003
Some warmth disappears when distortion goes out. Find the balance by tweaking your loudspeakers (or others) and you will in the ended be greatly rewarded. There are more references about this - here is one I think makes sense.... How to Make a Track Sound 'Warm' and 5 Other Confusing Audio Terms, Explained
A system is a balance act. Never will I weigh up something by adding distorsion - I just don't believe in that if you have high goals.
Then again... harsness and coldness could also be dist. :)
No Ideas? Looks like there is not much to mod. As for the electrolytic apacitors,there is only 2 for the USB input and one between a
regulator´s Output and the Sabre 9601 lineout/phone driver.
No data available if there is dedicted outputs for each prurpose.
If this highly integrated combo of DAC and preamp really sonnds as thin as it does against several dacs from several generations, Ess Technology did something essentially wrong...
BTW I am not using USB but a low noise power supply.
I would also like to know if the ES9018K2M has also current output (I doubt) to use/test it with a better output stage...?
In my experience the ES9018K2M doesn't have completely natural timbre. Go for a multibit DAC with discrete output stage (or transformer) for warmth.
As far as I'm aware, you can use either a low impedance input (current mode) or high impedance stage following the DAC chip. Internally its just a bunch of resistors between the reference supply and GND.
Well, i tested this DAC with two low noise power supplies,
from Twistedpear (shunt regulated Placid) and from LDOVR.
Setting the source to pause and ramping my amp all way up, there is a hiss.
My Buffalo DAC as well as an old Philips CD-304 are quieter.
Also the datasheets indicate that the ES9018k2k/Sabre9061k should be quieter.
I assume the hiss comes from the voltage regulation and that the first regulatior after the usb input can be omitted.
The ES9018k2m runs on 3.3/1.8V.
But I find no info on which voltage the Sabre9601k runs...?
Cheap Sabre dacs don't generally sound warm, IME. Power quality, AVCC reference quality, clock jitter, analog reconstruction filtering, digital interpolation filtering, etc., are all things that contribute to poor sound quality in them. It usually isn't like the manufacturer just did one thing wrong, usually they cut corners pretty much everywhere equally. As a result, there is usually no one simple fix. Very common scenario with low cost Sabre dacs, don't know about others so much. Haven't looked into any of those.
Why don't you? You could ring out the connections with a DVM and probably figure it out. If you blow it up, no big loss. It's more or less junk as is, IMHO.
Or, you could sign an NDA with ESS and get data sheets for the parts. Lot of trouble for not much potential gain starting from an ES9018 though, again, IMHO.
It may help to know that Sabre dacs only have one kind of output, it works for voltage mode or current mode depending on how it is loaded.
If interested in modding a Sabre dac knowing you will end up with something quite good, you would certainly be welcome over in the 'ES9038Q2M board' thread. Lot's of modding going on there. Having done some of it myself, there is not always a schematic or other desired information, but often one can still figure out quite a bit. Enough to make significant improvements. Actually, over there we do have a lot of information by this point, but a lot was done in the beginning with with no schematic and no datasheet.
The clock needs its own supply also, or at least some ferrite beads in there somewhere to keep the noise at bay if shared with dvdd.
That board needs so much to be sibilant-free and still sound decent, would be easier to just make some simple upgrades, put it back together and find something more mod-worthy.
Keep that one for a backup or test unit.
Amen to that. A little EQ is a better idea than hacking it.
es9018k2m are so super cheap now that it might make sense to get a US$8 6.5cm x 6.5cm one to experiment with if that's your thing?
ES9018K2M I2S IIS DSD??????DAC???? ?? DOP ???-???
Although on Ebay it is 3x the price.
ES9018K2M I2S/IIS DSD Digital Audio DAC Decoder Board Support 32bit 384k | eBay
Hi Salar,
Probably better if you come over there and we can talk about it there so that anyone else interested can read along. You picked a pretty good time to drop in as there is bunch of activity going on right now where people are starting to implement some of the latest mod versions. Unfortunately, I don't have a perfect summary for you, but I can point you to the latest we have and fill in some other odds and ends. And by all means, please feel free to ask any questions you want.
Best Regards,
Mark
