ES9038Q2M Board
ES9038Q2M Board
Thread Tools
Old 27th November 2020, 09:56 PM   #6231
Markw4 is offline Markw4  United States
Maybe it only applies to sync mode if entered by way of enabling 128_fs mode? (In that case there is the presumption of an external PCM interpolation filter.)
I believe sync mode can be entered by other means, which includes setting DPLL Bandwidth=0. In that case, if lock fails then a mute condition will occur.
Old 27th November 2020, 10:01 PM   #6232
potstip is offline potstip  Turkey
Hello Mark;
Thanks actually i am not using USB so it not possible for me to switch between clocks. So i have to stick with ASRC. I will use NZ2520SDA series clock. So regarding to clock selection i guess with 24.576Mhz i can not able to get 192Khz. Because acc to your comment here below on post #2058
"To figure out the maximum PCM/I2S sample rate you could get with a particular clock, divide the clock frequency by 192."
I can only reach 128Khz with 24.576Mhz clock. So i guess i have to go with 49,152Mhz.
Old 27th November 2020, 10:08 PM   #6233
Potstip,
It depends on the clock frequency specifications which are near the end of the datasheet. For async, IIRC MCLK has to be greater than 3 times the bit clock frequency. Been awhile since I looked at it though. For sync mode, again IIRC, MCLK is equal to 2 times BCLK or an integer multiple of that. Study the data sheet and you should be able to figure out what to try. If necessary I could review it again but I'm not here to do all the work for you.
EDIT: The native mode of the dac is 32-bit, which is probably something to keep in mind.
Old 28th November 2020, 03:48 PM   #6234
altor is offline altor  Israel
Not necessary to set DPLL=0 (DPLL_PCM and DPLL_DSD) because one bit in the next register can disable it at all.
P.S. Despite that DS says "no" DSD works in Sync Mode, at least <=dsd256.
Regards, Alex
www.altor.co
Old 28th November 2020, 04:01 PM   #6235
Seems to me Allo claims they have ES9038Q2M master sync mode working with DSD and DPLL Bandwidth=0. They had to work with ESS and XMOS to solve one problem that turned out to be an XMOS coding error affecting master sync mode with DSD, at least IIRC.
Old 28th November 2020, 04:17 PM   #6236
Did not use 9038Q2M, I made it with 9038Pro.
Regards, Alex
www.altor.co
Old 28th November 2020, 04:37 PM   #6237
meszarosa is offline meszarosa  Hungary
ES9038Q2M Board
I've tried DSD256(FS=11.2MHz) on ES9038Q2M(in slave mode), feeding es9038 with 2xFS, no success in async mode, but also no success in sync mode (DPLL=0). No sound. Any hints, how to make it work?
Old 28th November 2020, 04:55 PM   #6238
In async mode MCLK clock needs to be faster than for sync mode. There is a table near the end of the data sheet with info on that. Otherwise, for DSD256 in async mode you might try a 45MHz MCLK.
Old 28th November 2020, 05:17 PM   #6239
ES9038Q2M Board
I've tried : async mode with 45MHz works fine. (DPLL=1 stable) However, I've tried to divide down this 45MHz clock with a DFF to feed the DSD source (Ak4137), so the DAC and the DSD source were quasi-sync, but I had no success putting the ES9038Q2M in DPLL=0 mode (sync).
Old 28th November 2020, 06:55 PM   #6240
AK4137 actually uses a PLL to resample, despite allowing a reference clock which can help with stability. Therefore, some jitter can be present on the output. You might try reclocking the signals before they go into the dac. You might also try cleaning up power to AK4137 and any chips that pass digital audio to/from it.
ES9038Q2M BoardHide this!Advertise here!
Thread Tools
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 03:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 12:36 PM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 05:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 03:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 11:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
