ES9038Q2M Board
ES9038Q2M Board
Old 28th September 2020, 01:02 PM   #5951
Aldoszx is offline Aldoszx
Yes, I will try to do that.
Old 8th October 2020, 01:53 PM   #5952
Markw4 is offline Markw4  United States
Because things are pretty slow here today, a pic below showing most of the current state of the AK4499 eval board. As can be seen, ebay power supplies work great for everything (except Vref). Easily beats Topping D90 sound. Vocals are not grainy, nor are cymbals. They sound like whatever is on the CD. The eval board itself is upside down and on the bottom. The large-ish green board on top of it is something I made to run some experiments. Some of the circuitry is on the under side. Having acquired some data, a new experimental board is in the works. The Green/Yellow/Orange ribbon cable running around is my color code for I2C bus.
Shown in the second pic is the stack of HPAs used for listening tests. There are two SOA or near-SOA units from Neurochrome, and one Pass Labs HPA-1. They all sound different. Top and bottom ones are my favorites, with the top one getting most of the use by me. When Jam comes over to listen he likes to use the Pass HPA-1, which he knows very well (being the designer of it).
Old 9th October 2020, 09:05 PM   #5953
samoloko is offline samoloko  Bulgaria
Hi Daniel,
Is black pcb an balanced out opamp output stage
can you please give details
can this be purchased online
Originally Posted by Green77 View Post
Hi.
Just solder my PCB (not so Nice ) and i think itís working ok.
I think itís a big improvment from the orginal voltage mode anyway.
BR//Daniel
Old 10th October 2020, 09:12 AM   #5954
Green77 is offline Green77  Sweden
Hello samoloko,
It’s a balanced output stage (rca). Built as schematic (type) as in post #3003.
Maybe i can try to uppland gerber file later.
BR // Daniel
Old 10th October 2020, 08:17 PM   #5955
thank you
Old 13th October 2020, 12:25 AM   #5956
24century is offline 24century
Send a message via ICQ to 24century ES9038Q2M Board
Hi.
BR//Daniel
Does it has LPF for the 1st stage?
Old 15th October 2020, 09:22 AM   #5957
Hello,
Here is the Gerber file for the PCB i use in my dac.
It's from the schematic in post #3003, except that it doesn't have the unbalanced output.
Works for me but can't say for sure that's a correct PCB. And layout are for sure not optimized.
But a nice improvment over the voltage mode OP that are on the orginal dac pcb...
Reason for R13-R16 is throug hole (i put a SMD 1206 in parallel) is that i couldn't find smd parts.
So if anyone want to build this pcb choose either R13-R16 or R20-R23.
D1 and R19 is also an option, i use it to see that dac was on.
BR // Daniel
Old 16th October 2020, 02:26 PM   #5958
Can't really open up the zip Daniel, did you make it on a Mac?
Old 16th October 2020, 02:42 PM   #5959
Maybe try using 7-zip. Worked fine here.
Old 16th October 2020, 03:29 PM   #5960
...Maybe i can try to uppland gerber file later.
Daniel,
May I ask what program you used to create the gerbers? If we could look at the source files in the same program then it might be possible to make a few improvements. Hard to say for sure though. Just looking at the gerbers in a gerber viewer is pretty limited.
ES9038Q2M BoardHide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
