ES9038Q2M Board
ES9038Q2M Board
Thread Tools
Old 14th July 2020, 06:56 AM   #5781
kimschips is offline kimschips  Denmark
You could also look her��
Mr. Jung's ultra-low noise VREF - the GLED431
Old 14th July 2020, 11:33 AM   #5782
Markw4 is online now Markw4  United States
ESS recommends +3.3v +-5% for AVCC for each of the two AVCC supplies. They also specify low noise in order to minimize DAC distortion and noise.
As can probably be seen there are long discussions in the forum about all the different ways to design low noise references, and the various trade offs to consider. I don't think we should get sidetracked into that this early in the going. We are trying to focus on the bigger picture and not get deeper into the weeds than we have to.
Regarding Tom Jung's GLED431, here are Walt's later comments he appended to original article:
"Addendum of March 8, 2016:
The circuit originally shown with a LT6200 op amp was/is intended as a conceptual example of low noise reference voltage scaling, not a complete working regulator!
The LT6200, like many low noise op amp devices, also has a very high bandwidth. From that it follows that it can readily oscillate. There are past caveats here and elsewhere about using very high BW parts within regulators (AD797, etc). Always proceed with caution, and make good use of a scope to monitor the output."
If someone really wants to get into it and is equipped to do the design and testing for a +3.3v version with known good PSRR, stability, etc., then let me know and I will see about getting Walt's updated paper to you.
Old 14th July 2020, 10:27 PM   #5783
eightdigitword is offline eightdigitword  Scotland
What op amps were used in the 'OSB' word doc?
I have some AD797 spare and would be nice to use them. should i just use the ess 'Application_Note_Component_Selection_and_PCB_Layo ut.doc' as used on the reference board?
Old 15th July 2020, 01:11 AM   #5784
Regarding use of spare AD797, may I ask if they are new and therefore SMD? Old and possibly DIP? Assuming SMD, are you comfortable prototyping in SMD?
Probably best to make some updates to the original ESS recommendations, but they are a great start in multiple ways.
OSB.rtf circuit is laid out for dual opamps and DIP sockets, so it has been tried with opamps like LME49720 and OPA1612.
Old 15th July 2020, 06:16 AM   #5785
What About max6126 anyone worked with that?
Old 15th July 2020, 12:04 PM   #5786
Don't know if they make 3.3v max6136 any more. Some other voltages are still in production.
Old 16th July 2020, 10:56 AM   #5787
Hi Marc,
chips are DIP, I'll follow the ESS recommendations with my 797's see how it measures up.
ta
Old 16th July 2020, 11:57 AM   #5788
Okay. You planning to do stereo 3-opamp output stages and stereo AVCC buffers with the AD797s?
Old 16th July 2020, 01:59 PM   #5789
I am, yes.
Old 16th July 2020, 03:34 PM   #5790
Have you thought about taking control of the dac chip I2C registers with an MCU, maybe an Arduino?
ES9038Q2M BoardHide this!Advertise here!
Thread Tools
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
