ES9038Q2M Board
ES9038Q2M Board
Old 21st October 2019, 05:56 PM   #5111
damiangt3 is offline damiangt3  United Kingdom
Originally Posted by Markw4 View Post
For LT1763, probably wise to follow the advice in the data sheet on choice of input, output, and noise suppression caps.
Whether LT1763 or LT304x would be better may depend more on layout rather than regulator data sheet specifications. It helps for regulators powering HF/RF circuits to be dedicated to particular loads, located very near the load, and be mounted on the same ground plane as the load (in order to minimize ground inductance and or noise effects).
What might be best for you may depend a lot on your experience/skill at fabrication using small parts.
Looking at the job in hand, it shouldn't be too difficult, I'm going to be using some small 100v Wima MKSs. For the clock, there's already a 106C (10uf) tantalum cap in place, should I leave this or replace with a better quality electrolytic?
Regarding AK4137 board power, I used a Chinese LT3042 (with pass transistor) board as a +5v digital supply pre-regulator. AK4137 was powered by that since there are secondary 3.3v regulators on the board, just as there are on the dac board.
I have one of these, a useful board to have.
One thing I did find when using one LT3042 board to power all digital board functions is that a ground loop was formed between the +5v ground returns from the dac board and the AK4137 combined with the I2S ground connections between the two boards. Some I2S RF was apparently flowing between the two boards through the +5v power grounds rather than the I2S connection grounds, and that caused some audible degradation of sound quality.
What I did to verify and correct the problem was add some cable clamp ferrites on one of the power supply ground returns to the 5v supply. Adjust the number and size of the ferrites for best sound quality.
As an alternative to that I probably could have used two transformer windings and two LT304x regulators to independently power the dac board and the AK4137 board. Then I2S ground currents might stay where they are wanted and not go where they are not wanted.
That's really interesting to know, it's been a while since I had the board connected up, I did have that powered separately (using the NewClassD at the time).
However, since LT1083 regulators, and other good sounding analog stage regulators, tend not to be super high gain error-amp regulators they don't fully eliminate all power supply ripple in one stage. For that reason it can help to use two stage regulators and or one or two-stage RC filters before the regulators. LC filters don't usually sound as good. If using multiple regulator stages it can be helpful to use transformers with maybe 20v or 22v secondary windings. Then some voltage can be dropped across the primary regulator and a little more voltage dropped across the secondary regulator. It all depends on what lengths one is willing to go to in order to get the best sound quality.
This really interested me when you mentioned it earlier on the thread, this coupled with providing more voltage and not relying on the minimum needed for the LDO. For the LT3045s I have, they are powered by my Salas running at 7v, this has sufficient power for the LT1763s when I mount them.
Space-wise, I'm struggling, so using a R-Core with 2x15v and 2x6/9v might be worth considering.
Old 22nd October 2019, 12:16 AM   #5112
Markw4 is online now Markw4  United States
The caps and other components that come with the dac board (except for the ES9038Q2M chip) are all very cheap parts. I found that the ceramic caps were pretty piezoelectric (probably not X7R). Up to you what you want to do though. The compromised quality of components that come with the board is not as big a problem as the circuit design. That is to say, the dac really needs proper AVCC supplies and a 3-opamp output stage. If those things are being fixed, then it might make sense to fix other things too.
Old 22nd October 2019, 09:36 AM   #5113
Solve is offline Solve  Sweden
Solve's Avatar
I stumbled over Vivo Xplay 6 smartphone with ES9038Q2M inside.
Measurements:Soomal - vivo Xplay 6 Review: Audio - Soomal.com
Music is the only art in real time....
Old 22nd October 2019, 07:45 PM   #5114
Thanks Mark, having 'dumped' the output stage in favour of the offboard Twisted Pair, implemented an op-amp AVCC and moved all of the other DAC power supplies to a mix of LT1763 (next stage) and LT3045 there really isn't much left. Once I start to use the IIS route in from the AK4137 and 'remove' the onboard inputs this leaves 11 SMDs surrounding the DAC and the crystal.
I must get the Arduino connected!
Old 22nd October 2019, 11:02 PM   #5115
Have I made a mistake by removing the inductors whilst finding a point on the PCB for soldering the new power source?
Old 22nd October 2019, 11:11 PM   #5116
The inductors are presumably there to minimize noise from loads from getting into the power supply rails and adversely affecting other loads, and or possibly affecting performance of the voltage regulator.
Once dedicated regulators are available for each load then its not clear if there would be reason for keeping the inductors. Might do more good to remove them. Hard to know for sure without trying it both ways.
Old 6th November 2019, 01:18 AM   #5117
impuls60 is offline impuls60  Norway
Hi! Just fired up my highly modded 1.07 board and I cant get it to work. Only the display fires up.. I have a few questions regarding the operation of the board.
1. Are the input jumpers necessary when using the rotary switch?
2. Is the optical plugn'n play ?
3. Can I use the original inputs together with the IIS from a Amanero board?
4. Does the Amanero board board work with this 1.07 card straight away?
I also attached a picture of my board. The AVCC gets power from underneath the board(LiFe 3.3V) through the stock electrolytic cap pin holes. If anyone finds any mistakes on the board please let me know. All the new regulators measures 3.3V. Is there any way to find out if the dac chip is fried? Thanks for any help!
Old 6th November 2019, 01:35 PM   #5118
Shouldn't be needed, except J1 and J2 installed at the same time may lock up the controller so don't do that unless you mean to.
Don't know myself about that if the display is hooked up. If the display is disconnected then IIRC J1 selects optical input.
Yes. Amanero or other I2S source can be connected while SPDIF and or TOSLINK is connected. Jumpers J1 and J1 select which input will be used if the display is disconnected.
Depends where you bought the Amanero board from. Twisted Pear flashes the firmware for use with external clocks. If you buy directly from Amanero then the firmware uses the clocks on the Amanero board.
If it is a Chinese Amanero clone it uses its own clocks, but can't be flashed with new Amanero firmware or it will become bricked.
Picture is a little blurry. Hard to say much about it.
[/QUOTE]
[/QUOTE]
An oscilloscope would help greatly with determining that. Otherwise, no real way to tell if the dac clock is working, or what input signals may be present.
Make sure you have an output stage powered up.
You might try removing the display and disconnecting any volume pot, just to keep things simple. Then use J1, J2 to select I2S or another input. Before starting playback you should see Vref DC voltage on all the dac outputs and I/V output pins. When you start playback some AC voltage should start to appear on I/V output pins (which would be the audio).
Old 6th November 2019, 04:24 PM   #5119
Thanks for for the help Mark!
I now managed to get it to work! It was a combination of my optical on my pc not playing along and a cut trace to the inputs. It worked right away on dvd player I first tried before finding the cut trace. It turns out the optical is plug'n play, havent tried the other inputs yet. So theoretically my chinese Amanero board should work native? Is there any leds on the Amanero btw? Do know of any good treads on the Amanero board?
Old 6th November 2019, 04:42 PM   #5120
Chinese Amanero boards should work fine for PCM audio. If using Windows OS, then appropriate precautions should be taken to minimize added distortion caused by Windows Sound Engine. Please let me know if you need info on that topic.
Otherwise, there is not much one needs to know about Amanero boards except the pinout for I2S. Official Amanero data sheet shows that info: https://www.amanero.com/drivers/combo384-D.pdf
All you need are DATA, BCLK, LRCK and Ground.
Sometimes different names may be used for the signals, for example FSCLK is the same as LRCK (Frame Sync Clock is the same thing as Left/Right Clock).
CLK and DCLK are same as BCLK (Data Clock is same as Bit Clock).
EDIT: Amanero drivers may be be needed for Windows to recognize the device. They can possibly be downloaded from Amanero or you can ask the Chinese seller you bought from to provide drivers (which may be best). However, ASIO and native DSD won't work with the Chinese firmware. Only way around that is to get a better USB board. The recommended one is I2SoverUSB: I2SoverUSB - I2S over USB Audio
ES9038Q2M BoardHide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 03:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 12:36 PM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 05:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 03:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 11:09 PM
Copyright ©1999-2019 diyAudio
