ES9038Q2M Board
ES9038Q2M Board
Old 17th September 2019, 02:37 AM   #5022
Markw4 is online now Markw4  United States
Originally Posted by 888777 View Post
...Lusya AK4137...
Okay that link worked. Maybe you can ask a moderator to delete those last two or three posts without a working link.
Already have a board of that version here. They made things a little more compact, including the display and button which are now on the board rather than on a smaller board at the end of a ribbon cable. It is about the same as the old board in most other respects.
Bottom line, that one should be okay.
Old 17th September 2019, 03:44 AM   #5023
888777 is offline 888777  Russian Federation
display and sensor for the remote control is not difficult to bring) for me, or rather, for my wife it is important that there is spdif, she also liked es9038). what settings to set in ak4137?
Old 17th September 2019, 04:39 AM   #5024
...what settings to set in ak4137?
Instructions should be just like the ones for the old version which is at the bottom of the ad at: AK4137 Raspberry Pi IIS декодер DAC доска SRC аудио Поддержка I2S 32bit 384 K DSD256 DSD I2S IIS преобразования с ЖК дисплей Дисплей-in Усилитель from Бытовая электроника on Aliexpress.com | Alibaba Group
It expects a USB board with a connector having two rows of pins in order for it to read all the configuration information for input sample rate, DSD_ON, and Mute. We could probably figure out how to patch in a USB board that has those signals, but in a different pin layout format. However, some USB boards don't have all the necessary signals in which case you would have to configure the input for manually for each type of file being played.
Old 17th September 2019, 06:37 AM   #5025
Zbunjen is offline Zbunjen  Croatia
Originally Posted by Markw4 View Post
Generic should work okay.
I've found a local supplier of parts. Looks like they have some opamps (there is a NE5532 on the previous page too), caps are Jamicon, resistors ill take 1% tolerance
Also, each existing AVCC pin supply includes an electrolytic cap, an SMD ceramic cap, and an SMD inductor. The two caps are in parallel going to ground, and the SMD inductor connects AVCC to the existing 3.3v rail. If using opamp AVCC supplies, first remove the inductor or cut the trace to disconnect the existing 3.3v. The caps might be able to stay if the electrolytic is the right value, or you could replace it with a better one if you want. The ceramic cap can stay or go. I usually leave it.
Got it! Judging by the traces from the 3.3v rail, those are these 2
Vref goes to the standard 3-opamp output stage, if one is fitted. Otherwise, it serves no purpose.
So, i just simply dont connect Vref to anything? Ill just leave those connections open in case of an I/V output stage in the future.
Regarding your linked picture, if buying a pre-built LT304x module, it probably already has an output cap so no need to duplicate that (i.e. you can delete that first cap on the left in your drawing).
So the diagram is correct i presume, i didnt expect that.
Now to just wait for some things to arrive...
Old 17th September 2019, 10:26 AM   #5026
I connected ak4137 ... what can I say? cool) I haven’t done the power on the DAC yet. just changed the clock to crystec cchd. I will collect Nazar, then I will remake AVCC. I'm using lm317 / lm337 now. then I’ll deal with output and registers.
Old 17th September 2019, 10:30 AM   #5027
question. is it possible to connect lm317 without a stabilizer in the circuit instead of asm1117 3.3? adjustment is made using a variable trimmer. lm317 can give a voltage of 3.3 V, I checked it.
Old 17th September 2019, 11:49 AM   #5028
Some people have done it, LDO's are fine for digital power afaik
LT3042 is lower noise
Old 17th September 2019, 01:34 PM   #5029
It was in this connection that the DAC failed. lm317 for avcc. tps7a4700 each separately for watches and other parts. I was told above that the wound regulators could provoke a failure.
Old 17th September 2019, 01:37 PM   #5030
It bothers me that lm317 without a stabilization transistor may jump the voltage. and instead of 3.3 it may at some point become 3.5 which is already critical for avcc.
ES9038Q2M BoardHide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Copyright ©1999-2019 diyAudio
