ES9038Q2M Board
ES9038Q2M Board
Thread Tools
Old 11th August 2019, 09:54 PM   #4851
rfbrw is offline rfbrw
Originally Posted by mmerrill99 View Post
I never suggest this or tried to do that - I always said it was a good base for dipping ones toes in the ESS environment
I know. The limitation is all mine. The D10 can only offer a limited insight into the ESS environment. A limitation that grows if your starting point is the ES9038Q2M.
Old 11th August 2019, 10:12 PM   #4852
mmerrill99 is offline mmerrill99
No problem. Understood
Old 12th August 2019, 03:03 AM   #4853
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by JensH View Post
The noise may cancel to some degree. But the largest cancellation will probably happen when there is no signal. Once there is a signal close to full scale the VREF supply will primarily influence the positive output signal, whereas the negative going signal will draw current to GND.
Good points! More food for thought.
Old 14th August 2019, 08:05 AM   #4854
IVX is offline IVX  Ukraine
IVX's Avatar
My "board" finally measured here Review and Measurements of E1DA 9038S BAL Portable DAC & Amp | Audio Science Review (ASR) Forum
Let's do smth nearly impossible!
E1.
Old 14th August 2019, 09:04 AM   #4855
Ugg10 is offline Ugg10  United Kingdom
Originally Posted by IVX View Post
Looks really good, great to see you have tamed the ES Sabre hump - any plans for a version with coax (or toslink or usb) spdif input and stereo (unbalanced) rca output and possibly making it available in a bare bones version and a usb/5/9/12v power line i.e. a Khadas Tone Board competitor ?
Old 14th August 2019, 01:24 PM   #4856
Markw4 is offline Markw4  United States
My "board" finally measured...
Congratulations on showing well for such a small dac in the measurements!
On the other hand, I am still interested to find out how it sounds...
Old 14th August 2019, 01:37 PM   #4857
IVX's Avatar
Guys, I never go to copy something, especially in such a trivial "design" area like DAC chips usage. I offered the DAC board idea with built-in APx55_like THD analyzer but I meet pretty much zero interest here, as I remember. So I gave it up, almost. A big PCB without housing could be much cheaper vs tiny one assembled into the accurate case. I think toneboard_like PCBA may be $50 effortless, and logistic is minimal: buy parts, send it to the SMD soldering facility, that's it.
E1.
Old 14th August 2019, 01:47 PM   #4858
Guys, I never go to copy something, especially in such a trivial "design" area like DAC chips usage...
Chances are it sounds like it too. Designing for measurements is only one consideration. Ask Gustard, and similar.
By the way, Apple makes a small USB dac that measures very well too, and beats many others on price: Buy USB-C to 3.5 mm Headphone Jack Adapter - Apple
Old 14th August 2019, 02:31 PM   #4859
IVX's Avatar
Yeah, I saw the discussion where $300 DAC based on ES9038Q2M shows THD .015% and Apple $9 DAC outperforms it effortlessly. In my home probably any 3.5mm jack output what I only can find will outperform that stupid DAC too ))
Archimago's Musings: MEASUREMENTS: AudioQuest Dragonflies Reviewed! Dragonfly Cobalt, Red, and v1.2.
E1.
Old 14th August 2019, 02:37 PM   #4860
...probably any 3.5mm jack output what I only can find will outperform that stupid DAC too...
Yes, but it comes in such attractive packaging!
More seriously, designing for great measurements and great subjective sound quality is possible too. Its harder than trying to do only one or the other. Benchmark did a really good job of that with DAC-3, but while very good its age is starting to show, IMHO.
ES9038Q2M BoardHide this!Advertise here!
Thread Tools
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 03:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 12:36 PM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 05:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 03:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 11:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
