ES9038Q2M Board
Hello !
OpenUAC2 project implementation on custom HW with ES9038 is on the way :)
The STM32 USB->I2S work, I2S signals looks good but es9038 didn't generate any signal.
I can read and write through I2C on es9038, I was surprised as the i2c address of es9038 is not 0x90/0x92 like mentioned on datasheet but 0x48 ? There is also another strange thing as the res1 register default value is not b11001100 but b10001100 ?
Clock on es9038 is good, voltage rails on es9038 looks good, I certainly miss something on es9038 init. If someone know how to simply output a analog signal with I2S data ?
Reactions: 1 user
Oups a newbie misunderstanding!:LOL:
I tried several combinaisons of registers, last try I only made a reset cycle toggling reset pin these way: L wait 10ms H.
I think it's maybe my volume control in fault :
I have binary stream on I2S bus, I see I2S_WS frequency change accordingly with Fs (ie 48ks i2s_ws=48khz, 96ks 96khz)
I comment all other functions
Success not so far :)
I check if I have 1.2V on pin 15: ok
check pin 21 reset: high level ok
I test with a volume value of 0x0 no change
You totally right I have to get rid of all reference to ak4490r and rewrite these portion of code, I'm only doing a quick check to be sure dac is working.
Next step: will try to probe signals directly on dac qfn package but maybe not tonight, a short circuit is quickly happening at the end of a day:)
Yep, can read, write and read back registers.
DAC_DATA looks good streaming audio data
DAC_LRCLK is 96Khz
DAC_BCLK is around 6.144 Mhz
DAC_MCLK is 49.152Mhz (feed by stm32)
I measure those signals probing on a resistor network array, maybe solder between pads and es9038 are not good. I think about testing spdif input. Also output the lock bit /register 64 could be helpful for me, I can map on a led to see.
If it helps, attached is logic analyzer hex dump of the boot code for a Chinese ES9038Q2M dac. As can be seen there is a lot of looping and checking of status bits. Eventually on the last page, the code enables the dac audio output (in register 14, IIRC).
  • DAC Boot.pdf
Hello :)
Finally, it works :) it just work few second ago, so I have to properly understand how and why but... great!!!!
I had one issue, I used the i2c write meme function with IT this doens't works for me, I replace it with no IT it works :) bit7 set of reg14.
I modify these things:
and my init sequence:
I see on scope the wave is not stable, there is some issue to fix, but hw seems to be good and that was my goal for this week :)
Here the sinus of victory :)
Guys of you go skiing in my country (Grenoble/French Alps) I have some beers to share with you :)!
Reactions: 1 user
Unstable the way the signal generated by dac goes on/off/on/off not accurately measured that. I was on auto trigger. I have to spy i2c bus and RESETB bin to see what appends.
Also signal is noisy and very low in amplitude; I get max of +/-200mV (when I set reg15 volume register to 0x0, if I set more than 0x0 amplitude decrease accordingly this looks normal). I doubt I understand well the output stage of this dac, in first understanding I think it was a current output dac and then implement this schematic:
Opamps are powered with dual supply +5V and -5V and I need a single ended signal of max +/-1.5V peak amplitude, after I made a single ended to diff conversion as I need a diff signal for my power amp. Values of 400R for i/s stage is based upon typical current output dac of +/-3.9mA centered on a -6.2mA dc current, ex : https://mi-take.biz/system72/DAC2020/ES9038Q2M/ES9038Q2M_DAC.html
