ES9038Q2M Board
ES9038Q2M Board
Old 23rd May 2019, 04:37 AM   #4491
Markw4 is offline Markw4  United States
Originally Posted by abraxalito View Post
Custom winding isn't going to help with both low resistance (i.e. low copper losses) and keeping far from saturation. They're mutually opposed - the further you run from saturation for a given core material, the more copper losses you have to accept.
It also depends on geometry, core size and shape. A larger core for a power transformer would probably be more cost effective than silver wire.
Old 23rd May 2019, 04:53 AM   #4492
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Custom winding isn't going to help with both low resistance (i.e. low copper losses) and keeping far from saturation. They're mutually opposed - the further you run from saturation for a given core material, the more copper losses you have to accept. Silver wire would help to lower resistance I guess.
Yes - well, sort of
If your design intent is to have the core running at a lower flux density then it will have to be a custom wound transformer. All 'normal' Toroids will run the core at a pretty high flux, around 16 and up to 18 kGauss (1.6 / 1.8 T)
to get the efficiency up.
Having said the above, I'm not absolutely convinced that running lower flux will result in better sound. There are so many different factors that we are juggling here.
My best guess is there is possibly a sweet spot that is retaining most of the benefits of high core flux but just backed off from saturation a little more
to keep it well in linear region.
But I have not done definitive testing of this with all other factors being equal.
T
Old 23rd May 2019, 05:09 AM   #4493
Sounds reasonable.
Old 23rd May 2019, 06:28 AM   #4494
888777 is offline 888777  Russian Federation
Originally Posted by Markw4 View Post
May I ask if anyone has gotten started yet with Arduino or other means for accessing registers?
Hey. I already got the protection fee. Arduino's on the way somewhere. Ready according to your recommendations to change the settings es9038q2m. I removed the AVCC film caps like you said. And then removed the ceramic capacitors on the es9038q2m Board that filter the AVCC power line next to the chip. And the sound stopped being sharp. the problem went away. Through what service can I upload photos to the forum?
Old 23rd May 2019, 06:37 AM   #4495
You can attach jpg files less than 1MB in size if you click on the advanced editing button and or scroll down to the 'manage attachments' button located below the reply/editing window. The images will be stored at diyaudio. I usually crop pictures, then reduce jpg quality until file size is under the 1MB limit (assuming the file was too big to attach without editing).
Regarding film caps, I'm not sure which ones you mean. Perhaps I don't remember what you were using for AVCC before?
Old 24th May 2019, 01:51 AM   #4496
I use TPS7A4700 for AVCC. And to remove the sharpness in the sound, I added the output ldo film 47 nF. After your criticism, I removed them. now there are, if I'm not mistaken, 57 nF ordinary ceramics. Here is a photo. This is a temporary structure. To looked good and was easy to change something at any moment.
Old 24th May 2019, 03:32 AM   #4497
I started looking into using LDOs for AVCC, at least a little bit. So far only tried ADM7150 (a recent issue Twisted Pear Trident-SR). Didn't sound very good at first. Tried adding a 33-ohm, 1/2-watt resistor from the regulator output to ground. That seemed to improve sound quality some. I then increased the input voltage to the ADM7150 from 5v to 5.7v, and then to 6.7v (using an adjustable pre-regulator in this case). Sound quality seemed best using 6.7v for the input. I did not notice further improvement going to slightly higher input voltages, so I stopped at 6.7v to minimize unnecessary heating of the regulator.
I recently have been advised that it is not unusual for adding a resistor from the voltage regulator output to ground to improve sound quality in analog audio circuits. I kind of assume it works by reducing the source impedance seen by the load over a fairly wide range of frequencies. Similarly, I was advised that increasing regulator input voltage may also help improve sound quality.
Pretty soon I hope to be able to compare a few different +-15v regulators. More on that later.
Old 24th May 2019, 03:41 AM   #4498
OK. It is very good djob! I added 33 omh resistor. And then get out him. But I will try again today. And give you my feeling of this method. In now I give 5v. on ldo.
Old 24th May 2019, 03:53 AM   #4499
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Its certainly the case on the older, non-LDO regulators that the output impedance decreases with increasing load current. That's because the output device is an EF whose transconductance is directly proportional to its Ie. On LDOs with common-emitter output devices the effect is likely similar. With a MOSFET as pass device though the gm isn't a linear increase with output current but I'd still expect lower Zout at higher load currents.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 24th May 2019, 05:56 AM   #4500
Most newer LDO's do not have EF outputs which enables the very low dropout voltages that they achieve.
However, the OP device will still have a higher gm when running at higher currents, so we can still be talking about the same mechanism, being that the error amp is doing less work, so to speak.
But my intuition tells me this is an oversimplification of a more complex situation and we don't know the driver arrangement or the exact compensation network. The first thing I would be looking at is the regulator's transient response at various output currents and capacitor arrangements.
T
ES9038Q2M BoardHide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Copyright ©1999-2019 diyAudio
