ES9038Q2M Board
ES9038Q2M Board
Thread Tools
Old 4th July 2018, 06:23 PM   #1781
babolcs is offline babolcs  Hungary
HI,
1) in the attached picture you can see that I removed the 47uF CAP near to the OPA in between the 2pcs 2k2 resistors (red marked place)
2) the common point of the 2 pcs 2k2 resistors were connected to the real ground
Basically this modification is NOT compulsory, since the voltage devider do almost the same, but the real ground is better as the virtual.
(You can also remove the 2 pcs yellow marked resistors, but if you are lazy not necessary)
Since it is not a compulsory modification for the simmetric PSU, please do the suggested move only if you double checked.
And do only after the modification Mark suggested.
Old 4th July 2018, 10:56 PM   #1782
Markw4 is offline Markw4  United States
@babolcs, there is a bias network that biases the non-inverting opamp input DC voltage to 1/2 way be between the positive and negative power rails. That way if the negative supply is at ground or at -12v or-15v the bias will always be midway. I have outlined the bias network part of the board in a red rectangle in the picture below.
Also, if using a dual rail power supply I would agree that real ground would be better than virtual, since AC grounding at the node is accomplished with one or more capacitors. The node can be grounded in that case which will bypass the capacitors.
Old 5th July 2018, 03:58 AM   #1783
Yes i told exactly the same with other words :-)
Old 5th July 2018, 05:45 AM   #1784
Ian Greenhalgh is offline Ian Greenhalgh  United Kingdom
Thankyou for the details on the power connections, exactly the kind of info I need.
I just wish my parts would hurry up and arrive so i can start building!
Old 5th July 2018, 07:10 AM   #1785
I see, I think we cross posted.
Old 5th July 2018, 09:14 AM   #1786
Old 5th July 2018, 09:37 PM   #1787
Apologies if these questions have already been asked, but trying to find specifics in this huge thread ain't easy!
1. Is it a sensible, simple upgrade to swap the socketed op amp on this board for a better one?
2. There are 8x 100uf caps and 2x 47uF caps, all cheap electrolytics, is it a worthwhile upgrade to replace them with good ones such as os cons?
Old 5th July 2018, 09:59 PM   #1788
Originally Posted by Ian Greenhalgh View Post
1. Is it a sensible, simple upgrade to swap the socketed op amp...
2. There are 8x 100uf caps and 2x 47uF caps, all cheap electrolytics..
The socket is a diversion the designers seemed to put there to help sell boards to customers who don't know much.
There are some specific power supply issues that need to be addressed, but they are not primarily due to problems with the existing electrolytics.
To make a difference with the board you can start to hear and that will make you happy you are really doing something, you need to fix the AVCC power supply and fix the output stage from voltage mode to current mode. That is what most of the stuff I mounted on the bottom of my modded board is for. Do that and you will have your first big WOW! moment. (also need to redo the circuitry around the opamp socket on top to make it into a differential summing stage for the I/V stages, or find some other place you would like to put that circuit function.)
If you have read the ESS document I mentioned as being most important on their download page, that has most of what you need to know in it. You just have understand what it means you need do. They are not kidding when they say to use certain circuits and components (excepting Abraxalito suggested scaling some filter values which shouldn't hurt and might help with opamp loading. I will admit I also deviated a bit around that part of the circuit with good results, so I did not actually test that part of one of the circuits as shown in the document).
What you need to think about is how to lay out an AVCC power supply using the exact types of opamps, capacitors, resistors, etc., as recommended) And do the same for the I/V and differential summing. When I built the summing circuit I did not include all the filtering which might protect an amplifier and speakers downstream from some HF junk that would be better if it were not there. So, I would recommend the filtering using C0G caps and high quality, tight tolerance thin film SMD resistors, and the suggested scaled values are probably what I would use.
Unfortunately, there is no easy way to make satisfactory improvements by lesser means. Sorry. If it looks too daunting maybe best to stop now. Otherwise, if you think you are up for it then you should probably be working out how you want to do it. If you would like to sketch out a schematic of what you propose to build and draw how you are thinking of laying it out, please post them here and we will be happy to take a look and let you know if we find anything that could be an issue. That way you should be well prepared when you are ready to start.
EDIT: Also, I would probably also suggest if you haven't built anything with SMD parts, that maybe you find a scrap board with SMD parts you can remove and replace for practice, or maybe get one of the SMD practice soldering kits from ebay with a little pcb and some parts to solder. It helps to have some small diameter solder like .3mm 60/40 and maybe some 63/37 for when you want to avoid melting higher temperature solder. There are also youtube videos with helpful info if one is so inclined.
Old 5th July 2018, 10:46 PM   #1789
It does sound a bit daunting, but that is largely because I've never done anything quite like this before, with guidance I reckon I can do it.
My plan is to first build a good PSU for the board, get it running and then make some upgrades and add an output stage.
I have a few soldering irons, but I think I'll need to buy a finer tip for one of them as none of them have a very fine tip and I'm used to soldering fairly large connections, so your suggestion to practice first is definitely appropriate for me.
What does AVCC stand for?
I'm still waiting for some of the parts I ordered to arrive, when they do, I shall be posting pictures of how I intend to lay them out inside the enclosure and getting advice at every step of the build.
I've been learning to use TinyCAD and drew this layout for a simple PSU for the DAC board, do you think it will suffice or do you think I need to add more caps after the regulator?
ES9038Q2M Board-psu-layout-jpg
Old 5th July 2018, 11:08 PM   #1790
Maybe better to start off with LM317 and LM337 supplies for positive and negative. Make then adjustable up to +-18v. That way you could still use it later if you want to use post regulators. Or just buy a cheap board like that from ebay. You can also get them as fixed regulators and they are I believe later and better than the old ones you are thinking of. If you look at the data sheets for each one it shows you application circuits with everything there you would need. For rectifiers, it is good to use soft recovery diodes of some kind. Otherwise you can end up with some HF noise coming out of the power supply above the frequency the regulators can effectively smooth out. You could google soft recovery rectifier or look at devices like Hexfreds as one type of example. You might want to check the data sheet of any devices you are considering to see what the forward drop is. The transformer will need to be sized to allow for that.
In the ESS document there is a schematic for AVCC supply. There are two pins that should each have their own supply. It is a super critical reference voltage used by the dac that has zero PSRR so you need to make the supply the best you can and as close to the pins as possible. Some of the pictures and the pinout for the dac show where the pins are.
There is also a voltage divider and filter you need to make for each AVCC supply. It is shown in the schematic on the ESS downloads page. It is two 10k resistors to make a divide by 2 and with a 10uf electroytic to ground connected to the output of each one to make an output filter. The divided voltage is called the reference voltage in the schematics or Vref.
ES9038Q2M BoardHide this!Advertise here!
Thread Tools
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
