DAC blind test: NO audible difference whatsoever
Old 22nd November 2019, 04:45 PM   #1901
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by cmjohnson View Post
But I can tell you that you need to have a good enough test system in order to get a valid test on the product under scrutiny.
And it turns out good enough can be quite poor Can you hear a difference between 2 solid state preamps?
Old 22nd November 2019, 05:35 PM   #1902
Evenharmonics is offline Evenharmonics  United States
I'm not reading all of a 190 page topic. The specifications of the test system are unknown to me.
Can you name brand and model of some of those "good enough" components?
To draw an analogy in the field of photography, you can't expect to appreciate a 5000 dollar camera lens's better performance if you're attaching it to a 300 dollar camera body. In such a scenario, the cheap kit lens that came witih the 300 dollar camera may give just as good an image.
Aren't you forgetting the infamous car analogy which goes something like, "If you are comparing car performance, you wouldn't put $50 Sears tire on $150K performance car, would you? It's the same when you are comparing amp performance, you wouldn't use $50 speaker cables on $15K amp."?
BTW, you are wrong about the camera lens difference. They do make a difference in both high-end camera body and entry level camera body.
It may be simply that a superior performing DAC does exist but the system it's being checked out on doesn't have the transparency required to hear it.
As both someone who knows something of electronics and how to measure them, and also as an audiophile, I can tell you that when audio systems are extremely good, they become more transparent to changes made within them. I HAVE heard the difference between an expensive DAC (20,000 dollars) and a STUPIDLY expensive DAC (50,000 dollars) in a $200,000+ system and no I'm not buying it. Not the DAC or the system. While I could hear differences when A/B switching between them, that difference isn't worth it to me and it's totally out of my budget even if I wanted it. In truth I am happy with my existing system which is far less expensive. The upgrade bug isn't even licking me.
Was it a level matched and bias controlled test?
Old 23rd November 2019, 05:34 PM   #1903
Doppler9000 is offline Doppler9000  Canada
Actually, it is you that is wrong.
Obviously, if a sensor is out-resolved by a lens, substituting a higher resolution lens will not improve image resolution - the sensor is the binding constraint.
If a sensor out-resolves a lens, then substituting a higher resolution lens will improve the image resolution, up to the point where the resolving capability of the lens and sensor are the same.
A 16mp sensor will hit its limit before a 24mp sensor will.
See?
Old 23rd November 2019, 06:53 PM   #1904
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by Doppler9000 View Post
See?
No. I also think it is a poor analogy. Resolution is only a part of what makes a great lens. The lack of various distortions, improved contrast etc are visible even on an entry level sensor.
Old 23rd November 2019, 07:32 PM   #1905
Let us change “resolution” to mtf.
The point is the same.
Old 23rd November 2019, 08:06 PM   #1906
Why the analogies? They don't seem transferable to an audio context.
Old 23rd November 2019, 09:01 PM   #1907
Would you not agree that as you lower the fidelity of a test system, it becomes increasing difficult to discern subtle differences?
Old 23rd November 2019, 09:12 PM   #1908
It might depend what the differences are, in the thread I linked to, very small differences were heard on very poor set ups.
Old 23rd November 2019, 09:56 PM   #1909
See?
You obviously never compared images of high-end lens and entry level lens side by side when taken same object with same focal length and aperture.
Can you cite an example of objective DACs listening comparison which the cheaper / lower fidelity system didn't reveal the audible difference that more expensive / higher fidelity system did?
Old 23rd November 2019, 10:00 PM   #1910
rayma is offline rayma  United States
But that doesn't mean those differences would still be very small on a much better system.
DAC blind test: NO audible difference whatsoeverHide this!Advertise here!
Will a small cap value difference be audible? jb0194 Multi-Way 2 8th February 2012 06:39 PM
Audible difference between DTS and Dolby? arjscott Everything Else 3 1st February 2007 01:33 PM
Which caps make the most audible difference? TDWesty Solid State 5 31st January 2007 06:49 PM
BrianGT Basic v/s Premium - any audible difference ? percy Chip Amps 1 4th September 2004 04:18 PM
RC Tolerance -- audible difference r_s_dhar Analogue Source 6 11th August 2003 08:47 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
