tda1387 dac pcb "front end"
Old 12th January 2019, 10:55 AM   #451
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The 'base' (actually gate) voltage of 2.5V for J327 will work just as well for J56. A quick look at the DS shows the maximum Vth for both is -1V @1mA. Good luck with the soldering if you take the leap for J56 - remember to order the MFV package - the other one is even more of a nightmare to solder.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 31st January 2019, 04:48 PM   #452
pcgab is offline pcgab  United States
Looks like Mouser has the 327's back in stock:
SSM3J327R,LF Toshiba | Mouser
Old 31st January 2019, 06:46 PM   #453
twocents is offline twocents  South Africa
twocents's Avatar
Fantastic news. Thank you for the heads-up pcgab! Ironically I received most of my components today from Mouser via a local agent, including the replacement J56's.
they are super tiny. I can probably TRY to solder them using a friend's microscope but the main problem is the solder pads on the pcb are too spaced out for those tiny legs. I think I will rather order the J327's and wait a little longer.
Old 1st February 2019, 12:51 AM   #454
abraxalito's Avatar
What I do with the J56s is solder one (or perhaps two) legs onto the pads. Then bridge the second (and/or third) pin with a 0ohm 0603 resistor to the PCB. Depending on layout the resistor could be to the gate terminal in which case can be the gate stopper R (I use 330R to 470R).
tda1387 dac pcb "front end"Hide this!Advertise here!
FS: Nelson Pass "VFET2" Front End PCBs luvdunhill Swap Meet 35 26th June 2017 10:21 AM
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 7 10th December 2016 03:03 PM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 11:50 PM
amplifier "front end bypass" toobnoob Car Audio 6 1st October 2009 02:18 AM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 10:25 AM
Copyright ©1999-2019 diyAudio
