tda1387 dac pcb "front end"
Old 5th November 2018, 03:53 PM   #331
Hugh Jazz is offline Hugh Jazz  Taiwan
Banned
And it's done! 220pF Wima bypass on the 3K I/V resistors sounds fine. Actually sounds better than the es9018k2m... pretty impressive given an almost 30 year gap in tech between them. Here are the scope pics from earlier. I expect they would be better now but whatever. The 44KHz noise:
2.8MHz noise
Old 5th November 2018, 04:07 PM   #332
PJN is offline PJN  United States
Great work Hugh, now I'm going to be forced to try some of your mods on my copy. The problem is that I'm sure my hacking skills are not at your level. But if I screw up I won't be out much.
Old 5th November 2018, 05:01 PM   #333
Alexandre is offline Alexandre
Good stuff Hugh, but I cant see any of your measurements (Id like to). Indeed this is a good option for low power consumers such as the tda1387 and tda1545.
My friend Jocko Homo would probably use green leds for the reference, with a CCS made of one DNMOS or NJFET. He seems to be concerned with noise at very low frequencies, always. I should do some experiments and try to hear the differences. Measuring sub-Hz stuff is hard and very time consuming.
Alex
Old 5th November 2018, 05:18 PM   #334
Oh, and he would NOT use an oscon for that position; leakage = noise!
-Alex
Old 5th November 2018, 11:43 PM   #335
Banned
Yeah sorry, no measurements, I don't have the gear to do them, and I guess that this wouldn't measure that well anyway given the numbers in the datasheet aren't impressive by modern standards.
Yes, that filter needs a low leakage cap but the Oscon is the only small 47u I had so I didn't even think about it ;-) I'm not sure I'd actually hear a difference though - I cannot hear any background noise at all. Maybe just squeeze out a little more resolution. Anyway, it should be quite easy to replace so thanks for pointing that out. I have yet to finish the buffer op amp resistors so I'll replace the Oscon when I do them.
Old 6th November 2018, 03:43 AM   #336
Hugh, some of your attachments cant be seen, at least by me. If I copy and paste the URL I get this:
This site is marked private by its owner. If you would like to view it, youll need two things:
A WordPress.com account. Dont have an account? All you need is an email address and password register here!
Permission from the site owner. Once you've created an account, log in and revisit this screen to request an invite.
Alex
Old 6th November 2018, 06:04 AM   #337
Banned
Yes - that's Wordpress' security. Sorry. Here they are as attachments. Not great and arguably would still create audible IMD, but much cleaner after fitting the THS4031. The MHz noise coming out of the IC went from a constant 400mV to an output modulated and decaying/ringing 40mV peak to peak
Old 20th November 2018, 01:25 PM   #338
zgtc is offline zgtc  Europe
zgtc's Avatar
Originally Posted by matt_garman View Post
Let the fun begin! I whipped up a quick schematic for you, see attached.
I wasn't gone, just got the ICs in my box! I just need the SOP8 to DIP8 boards now and will start soldering the very basic implementation asap. Will keep you posted. TY again.
Old 25th November 2018, 12:49 PM   #339
zgtc's Avatar
Hey Matt, I have all the pieces, starting to build this basic implementation from page 30 on a breadboard. Already soldered the DAC into a socket converter to make it easier to work with.
Hopefully "TO_RIGHT_AMP_CHANNEL" and "TO_LEFT_AMP_CHANNEL" are self-explanatory.
Let me know if you have any questions!
Sorry I think this is the most stupid question, but RIGHT and LEFT should be used with a GROUND as well, right? So, one cable using ground and LEFT to the left amp input, and the other cable using ground and RIGHT to the right amp input. I have some spare RCA cables I can cut and reuse, if this is correct.
Thank you
Old 25th November 2018, 07:06 PM   #340
zgtc's Avatar
Following my question above. I can only hear a loud noise, not music. Same noise as if I touch the RCA tip (as if I was the source) but louder. Any suggestion? TIA
tda1387 dac pcb "front end"Hide this!Advertise here!
FS: Nelson Pass "VFET2" Front End PCBs luvdunhill Swap Meet 35 26th June 2017 10:21 AM
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 7 10th December 2016 03:03 PM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 11:50 PM
amplifier "front end bypass" toobnoob Car Audio 6 1st October 2009 02:18 AM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 10:25 AM
Copyright ©1999-2019 diyAudio
