7.1 DAC audio preamp for video
Old 9th November 2018, 07:01 AM   #11
carlmart is offline carlmart  Brazil
Originally Posted by Kal Rubinson View Post
Currently, not available for sale.
But you have it here, costing less.
6Way 6Channel Motorized Remote Volume Control Input Selector KIT Audio Amplifier | eBay
The question (for me) is how to make the X6000/ST6000 work so as to assemble a 5.1 or 7.1 preamp.
Old 9th November 2018, 07:14 AM   #12
UV101 is offline UV101  England
UV101's Avatar
That kit is an input selector not a multichannel volume control.
You need to handle volume control and delay in whatever is decoding the DD and DTS. Also you are missing the whole room correction and tone control that goes with a dedicated processor and that is a must for setting up this kind of system.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 9th November 2018, 07:55 AM   #13
Sorry, you are right. You need a pot like this for that:
ALPS 6x100KA 6-Gang RK16812MG LOG Stereo Motorized Potentiometer Pot 1pc | eBay
Old 9th November 2018, 07:57 AM   #14
You do not need room correction or tone control, in fact I should avoid such correction.
You only need level correction for each channel. That you can do individually for each channel.
Old 9th November 2018, 02:53 PM   #15
UV101's Avatar
Is this for "Cinema" use? I think you'll be in the significant minority if you don't want any signal processing (unless you sit in a a anechoic chamber, equidistant from each identical speaker)
I'm not sure I follow what you are actually trying to achieve.
If you are looking for a replacement for your Onkyo (junk known to fail) and Denon (should really have lasted better), there is a reason they are packed with DSP and that is because you need it to make the effects work properly.
I'm slightly confused by your use case???
FWIW, I use a 2 channel pre/power set up for my hifi. Here I have a valve preamp into a big power amp. When the valve pre is on, the whole cinema set up is totally isolated from the 2 channel system. When the pre amp is powered down, the FL and FR preamp outputs of the Marantz processor are fed to the power amp (passive pass through) as part of my 9.1 set up. The result is totally uncompromised 2 channel sound for hifi and totally configurable cinema audio when required.
Without understanding why you think you need 6 channels of DD or DTS which are not configurable, I cannot see why you would want to go down this route.
There are not enough connections on this to control 6 channels!
Old 10th November 2018, 12:20 PM   #16
Sorry, but who told you that room equalization is part of the multi-channel level setup? AFAIK only the levels are adjusted.
I have been an audio engineer for movies for about 40 years, and I think my ears have served me and still serve me well to identify an equalization not belonging in the audio track itself. I do not need an anechoic chamber to tell me that.
What I'm trying to achieve is very simple: eliminate receivers. I still need a 5.1 channels preamp, even if I will not be using the .1 surround, as I believe in having my low bass coming from the L/R channels.
I just need the system to feed in an HDMI signal, separate the channels, decode the Dolby/DTS and feed out the analog outputs, that I will input on quality power amps. No equalization of any kind for me, thank you, only that required by Dolby or DTS to recover the coded audio.
If the preamp has a levelling system inside, that's fine. If not I will use my studio microphones and level meters to adjust the channels levels on each amp, adjusting the gain.
Why do you think you need DSP or any equalization to make effects work properly? Where did you read that? DSP is just a tool for certain things, but certainly not essential to 5.1 to work properly. Once again, you are mixing electronic room equalization, which is debatable, with Dolby/DTS processing.
I intend to make it different, using an input selector switch on the L/R amps to get audio from a dedicated Raspberry, probably, connected to my network, with its own DAC.
Who said I do not want them configurable? I just don't want them equalized.
I'm not sure how they are wired inside. They claim to be 6-channel pots.
But there's also these other two:
Panasonic 6-Gang A10K 10K Audio Motorized Potentiometer 25mm D Shaft | eBay
ALPS 6-Gang A100K 100K Audio Motorized Potentiometer 25mm D Shaft | eBay
These seem to have enough pins for each channel separation.
Pity they do not come in other Kohm values.
7.1 DAC audio preamp for videoHide this!Advertise here!
DIY STEREO MIC-PREAMP for DSLR-Video Salar Analog Line Level 3 18th April 2012 01:33 PM
Audio/video sync. Little help please? peace brainerd Solid State 4 19th December 2011 06:03 AM
Elekit preamp assembly video from Winston vkung Elekit 0 1st November 2011 04:36 AM
Using Video-DACs for audio ojg Digital Source 18 22nd December 2003 05:03 PM
Copyright ©1999-2019 diyAudio
