Wadia x64.4 sledgehammer output stage problem
Old 15th September 2020, 03:35 PM   #21
RobertS61 is offline RobertS61  Netherlands
That would be even greater but there's some controversy on that diamond buffer issue:
RJM Audio - The B-board Buffer Stage
Can't discuss that with you because lack of knowledge, but they put them in for a reason, I reason
Old 16th September 2020, 07:29 AM   #22
Originally Posted by analog_sa View Post
These, being diamond buffers with no voltage gain should be easy enough to troubleshoot even without a scope. Just take them out and jumper IN to OUT.
It may even sound better that way.
Now I understand what you say.
Solder them out and short the PCB pin inserts where pin 4 and 8 where?
HA5002:
https://www.diyaudio.com/forums/atta...1&d=1600241481
https://www.diyaudio.com/forums/atta...1&d=1600241271
Old 16th September 2020, 10:01 AM   #23
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Yes. The buffers are there in order to drive longer and higher capacitance cables. In some situations the buffers may be beneficial, but they also steal some transparency.
Old 16th September 2020, 10:09 AM   #24
The Yes part of your answer means I can pull those opamps out and short pin 4 and 8?
  Reply to this post
Wadia x64.4 sledgehammer output stage problemHide this!Advertise here!
Sledgehammer to crack a Lightspeed walnut number7 Solid State 21 21st October 2016 10:02 PM
CR Kalypso Amp with output stage problem- Please help! Andyroid Tubes / Valves 3 25th January 2014 10:12 AM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Analog stage WADIA XXX Digital Source 0 29th January 2007 02:20 PM
Mismatched drivers in output stage - is this a problem? Dave S Solid State 17 29th November 2005 09:30 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
