Valve DAC from Linear Audio volume 13
Old Yesterday, 08:01 PM   #81
MarcelvdG is offline MarcelvdG  Netherlands
The simplest and cheapest approach is to ground the negative outputs of the main PCB (with the 10 uF DC blocker capacitors still in place) and to use single-ended filters. I tried that on the complete valve DAC and got an increase of about 3 dB of the noise floor, but otherwise it worked fine.
Old Yesterday, 09:10 PM   #82
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Thanks Marcel and, yes, I'll probably try that in the first instance or, maybe, even one of these (just to prove the DAC works - I've got a spare one here somewhere);
DRV603 board - I2S over USB Audio
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 69 14th June 2016 02:46 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Copyright ©1999-2019 diyAudio
