Valve DAC from Linear Audio volume 13
Thread Tools
Old 14th September 2020, 06:51 AM   #861
Mikky1975 is offline Mikky1975  Italy
Thanks Ray, just PMed you!
Many thanks to you and the whole community.
Mirko
Old 14th September 2020, 07:42 AM   #862
nautibuoy is online now nautibuoy  United Kingdom
nautibuoy's Avatar
Having exchanged PMs with Mikky1975 we have clarified his requirements and I have adjusted the GB spreadsheet accordingly.
As it turns out he only wants one PCB so I have one left if there are any more lurkers out there? I won't be running another GB so this may be the last opportunity.
Also, an apology - in slotting Mikky1975 into the spreadsheet I realised that I had omitted to include the cost of the smd stencil so the figures for the smd soldering service have increased a little - sorry about that.
Old 14th September 2020, 05:52 PM   #863
nautibuoy's Avatar
I posted another set of bare PCBs to Pistolerro this afternoon. Only one more set of bare boards to dispatch once I get a delivery address from dubulup.
The boards I posted last week should be landing very soon.
Old 14th September 2020, 10:34 PM   #864
spm is offline spm  United Kingdom
Boards arrived today.
Look very good.
Now the fun begins!
Thank you.
Simon
Old 15th September 2020, 03:35 AM   #865
agent.5 is offline agent.5  United States
Having spent a bit of time laying out the boards last couple weeks, this is what I have so far. A 4 layers pcb for the isolators and a separate 2 layers power supply board, that the isolator pcb can plug onto. I may have gone a bit crazy on the via fences. But this is what Analog does on the EVM. So, I just copy it. In addition to revised schematics, based upon Marcel's advices, I have the 3D renderings of the top and bottom of the two pcbs, and separate printouts of each copper layers. On the 4 layers board, the inside layer 1 is ground and insider layer 2 is power. But, it is mostly ground anyway, as I used traces instead of a pour. I also did a little adapter board to P13. Suggestions?
Old 15th September 2020, 03:37 AM   #866
There are more files of the power supplies.
Old 15th September 2020, 04:26 AM   #867
wow that was quick. I think that I already found an error. R3 should be next to U3 than U5.
Old 15th September 2020, 05:45 AM   #868
nautibuoy's Avatar
Look very good.
Now the fun begins!
Thank you.
Simon
Great. Have fun.
Old 15th September 2020, 05:54 AM   #869
nautibuoy's Avatar
Originally Posted by agent.5 View Post
...this is what I have so far.
Interesting.
I've only had a quick look at your attacments and sorry if this has been covered before; I don't see any oscillators?
What sort of separation distance (i.e. Ethernet cable length) between the two boards are you envisaging?
Correction: Ah, I see, external oscillators via J10 & J11
Old 15th September 2020, 07:51 AM   #870
rfbrw is offline rfbrw
Boards turned up monday morning. Thanks and much kudos to you and MarcelvdG.
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Thread Tools
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 71 27th October 2019 02:52 PM
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
