Valve DAC from Linear Audio volume 13
Thread Tools
Old 17th November 2019, 03:59 PM   #361
MarcelvdG is offline MarcelvdG  Netherlands
You could connect the raw DSD signal you want to test to an input of the filter board via a resistor (anything from 560 ohm to 2.2 kohm will do) and a DC blocking capacitor (preferably in the 10 uF to 100 uF range), leave the other input open and listen to the output signal. The output signal will be softer than line signals usually are and the filter will behave as an overdamped second-order filter, but that doesn't matter much for a simple functional test.
Old 17th November 2019, 04:11 PM   #362
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Marcel, have you picked up on this thread?
STAR Pure DSD DAC-Signalyst New
Maybe the CT7302PL gives you fresh options for a future Valve DAC (or discrete Silicon DAC)?
Ray
Old 17th November 2019, 04:51 PM   #363
Hi Ray,
Thanks for the link. I had heard about the existence of the CT7302 and other asynchronous sample rate converter chips with DSD outputs, such as the AK4137. In fact the CT7302 has an evaluation module that you could connect straight between any old S/PDIF source and the DSD-only version of the valve DAC (or any other DSD DAC):
http://www.comtrue-inc.com/images/CT...oard%20APN.pdf
For me, designing my own fifth- and seventh-order digital sigma-delta modulators and learning more about FIR filter design and FPGA configuration was part of the fun. If I ever make a new valve DAC, it will probably use a cheaper FPGA board and have the ASRC included in the FPGA.
Marcel
Old 20th December 2019, 07:29 PM   #364
Hi Ray, is there any news?
Old 20th December 2019, 07:34 PM   #365
nautibuoy's Avatar
Hi Marcel, slow progress at the moment I'm afraid - too much else on my plate!
I have some leave over Christmas so I hope to make some more progress in the next week or two.
Sorry it's taking so long.
Old 20th December 2019, 08:16 PM   #366
snax is offline snax  United Kingdom
Hi Marcel / Ray.
The year has definitely been a hectic one.
I finished a contract recently and had time to populate some of the board.
Sorry for the amount of flux. I have read your warning, Marcel and it will be cleaned from the board before testing.
I have wound the pot cores and I am currently putting a KiCAD image together so I can do a home brew regeneration board.
Will post again when I have the regen board populated.
Old 20th December 2019, 08:34 PM   #367
It looks like it will be a challenge to mount those Russian 15 nF filter capacitors...
Old 20th December 2019, 08:46 PM   #368
Hey Marcel,
They will stay on top of the board... its the 10uf under the board that I'm struggling with. I'm never one to shy away from a challenge and those SMD's were... satisfying!
I am using an AK4137 board that i picked up in Korea to convert PCM to DSD. It recognises the input correctly but I don't have any way of testing if the DSD256 output is working yet. It's on my bucket list of things to do.
Old 20th December 2019, 09:06 PM   #369
Ah, I didn't realize those were the output coupling capacitors. I thought my capacitors were big, but they are nothing compared to these!
You probably already know this, but you can functionally check a raw DSD output with an RC low-pass filter at 20 kHz or so, for example 820 ohm and 10 nF or 2.2 kohm and 3.9 nF. Connect the DSD output to the filter, AC couple the filter's output to an amplifier with volume control using a coupling capacitor of a few microfarads, make sure not to turn up the volume too high and check if you have sound. The reason for not turning up the volume too high is that at high volumes, the remaining ultrasonic quantization noise might damage your tweeters or your amplifier.
Old 20th December 2019, 09:15 PM   #370
I didn't but I do now.
It been a bit of a steep learning curve with a few moment of sobriety to keep my interest.
Cheers.
Have a fabulous Christmas if I don't post before.
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Thread Tools
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 71 27th October 2019 02:52 PM
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
