Valve DAC from Linear Audio volume 13
Thread Tools
Old 14th June 2021, 07:46 AM   #1871
acg is offline acg  Australia
Nice stuff Sonny.
Old 14th June 2021, 04:04 PM   #1872
agent.5 is offline agent.5  United States
Congrat Sonny. Looks really nice.
Old 14th June 2021, 05:32 PM   #1873
pgour is offline pgour  Greece
Beautiful built, congratulations.
Old 18th June 2021, 12:31 AM   #1874
SonnyMarrow is offline SonnyMarrow  United States
I'm getting a decent amount of noise, and I noticed that my circuit ground has about 25-30mV DC in relation to the chassis. I have the ground connected to chassis through a ground isolator (House GND Kit). The DAC is connected to the ground isolator using that middle pad on the filter board connected to the ground plane.
What's even weirder, is when I bypass the isolator by touching a different chassis wire to the ground, there is a little tiny spark. What could be causing voltage to leak into ground?
Old 18th June 2021, 01:35 AM   #1875
Ignore my post about noise. The connection from the ground of the output board to the ground isolator thing wasn't good. Still don't know why there's a little bit of voltage, but it's fine regardless. I still need to debug the optical and USB, but for now I'm just enjoying it with BNC. Really wanting some nice tubes for it now...
Old 18th June 2021, 07:13 AM   #1876
Looks excellent Sonny. Have been really enjoying the sound of mine while still on the breadboard.
Old 18th June 2021, 04:36 PM   #1877
Hans Polak is offline Hans Polak  Netherlands
Sonny,
You are a true mechanical wizzard.
What a meticulous piece of art.
Hans
Old 18th June 2021, 06:26 PM   #1878
wlowes is offline wlowes  Canada
wlowes's Avatar
Truer words were never spoken Hans...
Old 3rd July 2021, 01:28 AM   #1879
For the life of me, I cannot get USB to work. I'm using a WaveIO (http://www.luckit.biz/documents/WaveIO/WaveIO_Infos.pdf).
I have the J6 header of the WaveIO connected as follows to P9 of the ValveDAC:
Data (DT) to pin 5
Word Clock (LR) to pin 11
Bit Clock (BC) to pin 9
Master Clock (MC) to nothing
Vin (V+) to pin 19
And all grounds are connected to the adjacent P9 grounds
P9 pin 1 is connected to an extra contact on my input selection switch. It is wired so that when USB is selected on the switch, P9 pin 1 is then connected to SW3 pin 5 (GND). SW3 pins 1-4 (the other inputs) are connected to nothing.
P9 pin 3 is directly connected to ground using a jumper to P9 pin 4.
The WaveIO J9 has an L8 pin that is described as a mute function, I don't have that connected to anything.
My PC is detecting the WaveIO and the WaveIO driver is detecting the signal rate of the songs just fine.
EDIT: Upon further testing, I think I have a bridged connection somewhere on the ValveDAC. With nothing plugged into P9, pins 17-20 all have continuity to ground.
Old 3rd July 2021, 02:17 AM   #1880
The issue appears to be the FPGA? When the FPGA is plugged in, 3.3V on P9 and P7 both connect to ground. When I remove the FPGA, the 3.3V is no longer connected to ground.
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Thread Tools
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 71 27th October 2019 02:52 PM
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
