Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#1071 |
How critical is the voltage on the HT supply?
I have a 260VAC transformer instead of the specified 230V trafo. I will drop voltage by using higher R values in the RC nodes of the supply line. May I drop a little less or more voltage than the 41 volts that calculation suggests? Would like to use resistors from the box. |
#1072 |
There is a quantity error in the BOM list for the through-hole components:
pos.61 R14, R25, R26, R27, R103, R104, R105, R106 Resistor_Vertical_RM5mm Quantity 4 value 2K0, 1 % Quantity needs to be 8. |
#1073 |
changed plans for me. I will not build my DAC. Added my circuit board + suitable R-core transformer in the Swap Meet forum if anyone is interested. Thanks Ray and Marcel! And for the others in the group purchase, good luck with your builds, will be interesting to see the results! / Micke |
#1074 | |
During start-up, only the voltage divider R47, R43, R139, D16, R140, R141 loads the -300 V supply, so the voltage drop across R132 and R136 will be less than normal and the transformer will deliver a bit more voltage than normal. If needed you could consider replacing R136 with a series connection of a Zener and a resistor, to reduce the difference in voltage drop between start up and full operation. Once everything is heated up, if you manage to get the negative supply somewhere between -290 V and -330 V at nominal mains voltage, that should be OK. Do you happen to know the unloaded voltage of your transformer (or equivalently the regulation) and the VA rating? |
#1075 | |
I did a sim in PSU Designer, assuming 10% regulation. This does look ok, given that C1-47uF is a 500V cap. I will see how it turns out, the Zener is a good idea and another option. |
#1076 |
Hello again. Just was thinking of a variant of the RAW DSD512..
I'm been thinking of a version of this with 6SN7s. With two triodes per envelope and medium mu, it got me thinking as the 10mA differential output should be used to drive a push pull configuration of two 6AS7s in OTL for headphones (I'm designing a PP 6SN7/6AS7 OTL headphone amp at the moment in LTSpice). Three 6SN7s could provide the 6 triodes needed in small neat headphone sized amp package. * 6SN7 coping with MHz in real life vs simulation. Gut feeling is that it probably won't have a problem. * Cross talk vs higher B+ to Va/Ia - I suspect this may cause more RF issues in close proximity. one option is to allow low Hz (DC) and high Hz (rise/fall of the digital signal) only using a blocking filter. * Reconstruction filter - the temptation to put this between the 6AS7 and headphones but would have to play with a simulation. I may quickly knock up a simple DSD512 clocked LTSpice simulation - perhaps use a input file with DSD512 and then output a WAV file and see (although this may take some time to simulate). |
#1077 |
Looking in a different direction, I have wondered previously about a version of Valve DAC using a Russian subminiature valve equivalent to the E88CC to make the board smaller/cheaper - 6S28B or 6S29B seem to be suitable but are only single triodes so the opportunity for a smaller board largely evaporates with the need for twice as many valves.
IIRC 6N16B is a well regarded dual triode sub-min equivalent to the 6SN7? |
#1078 |
6N16B double triode miniature tube → OTHER tubes → Tubes-Store.com
Hmm interesting.. less power handling but that's to be expected. I think it depends a little on what it's driving on the next stage - 6AS7 needs a fair whack of current. I can't read Russian but ... hang on full stats here: 6N16B-VI Double Triode Miniature Tube MELZ Soviet Russian NEW all photos and images | photorp.com curves: https://photorp.com/media/photorp/vi...ure-tube-1.jpg ![]() Last edited by NickKUK; 3rd December 2020 at 08:07 AM. |
#1079 |
Do - edit timed out as I was playing with the load line calculator (Triode / Pentode Loadline Simulator v.1.0 (20161216 www.trioda.com)). Looking at the load line, in the architecture we have for the valveDAC the valve will see the 16Kohm resistance (Ra) as it's got two 32R in parallel. A 0-5V grid (not using ±2.5), 153Ua, 16K Ra, will see ~ 2.59mA Iq (10mA at 0Vg, 3mA at about -5Vg) mu of 22.5V/V. There's still a little more you could give the tube by increasing the anode voltage.
Maybe I'm wrong and need of another coffee after a 5am start.. Last edited by NickKUK; 3rd December 2020 at 08:48 AM. |
#1080 |
Well got the 6SN7 model running on LTSpice lol - DSD512 simulation
![]() Screenshot 2020-12-03 at 14.04.19.png This is literally the same voltages so probably not the best for the 6SN7's performance but it's 'working' (there needs to be a load of testing for distortion etc) plus I've not put in part of the filter (Lundhl transformer not in) so there's likely to be a load of digital signals output. I also had to use the 74HC74 which is 0.5V instead of the 74HCT74 which is 1.3V due to LtSpice model availability. Last edited by NickKUK; 3rd December 2020 at 02:22 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
13.8V 80A Linear PS circuit design analysis for Ham Radio Use | FJHookah | Power Supplies | 71 | 27th October 2019 03:52 PM |
Is it tradition that we use linear PSUs for valve amps? | Paul Uszak | Power Supplies | 9 | 2nd September 2016 11:58 PM |
Audio Valve Eklipse volume pot value? | Ki Choi | Tubes / Valves | 0 | 27th March 2015 06:22 PM |
Londog Audio VDt1 Valve Output 24/192 DSD DAC | mainscablesrus | Mains Cables R Us | 1 | 1st October 2013 07:52 PM |
Audio Note DAC 2.1x valve DAC | juancho | Swap Meet | 0 | 6th July 2005 10:16 PM |
New To Site? | Need Help? |
