Oppo Sonica DAC
Oppo Sonica DAC
Old 4th November 2018, 06:07 PM   #91
Coris is offline Coris  Norway
Coris's Avatar
Oppo Sonica DAC
I agree, a very stupid design, when using both ESS9018 and 9038Pro chips. In Oppo players two of the DAC chip output pairs are wasted for headphone. Even more stupid in Sonica, the two channel pairs are just grounded and not mapped by software (firmware).
A possible explanation of this design in case of Sonica (as mentioned above in wealas post), is that the ESS9038Pro it need a particularly analog output circuit. This new design didn`t want Oppo to design, or they did not know how to do it. So they used the same old circuit, since 105 model.... Bad!
However, this old circuit it can be adapted to receive two of the ESS9038Pro channel pairs (paralleled). I did this experiment with good results. Maybe Oppo didn`t...
So, in Sonica they could map two and two channel pairs, one pair for XLR and the second pair for RCA. They chosen to ground it...
Unifying the two channel pairs either for 9018, or 9038Pro, I do currently (as standard) in my mods. Then I connect my output module to the unified differential channels, and this module it then split the DAC analogue out to XLR and RCA. I do it the same for Sonica a s well.
Unifying the DAC output channels is quite simple: just connect together DAC-A outputs in between, and DAC-B together as well.
Well, the further original circuits have to be modified a little bit to fit with the two output channels paralleled... If the original analogue post DAC circuits are used with paralleled DAC outputs, a decision about either XLR or RCA out have to be also taken.
Old 4th November 2018, 07:50 PM   #92
wealas is online now wealas
If you can find the i2c lines to the DAC chip you can probably use a small arduino module to change the channel mappings after the factory controller configures the chip. Might have to monitor the i2c line state to determine when the factory controller is not talking to the chip or just try few times until you get it to change.
Old 4th November 2018, 09:23 PM   #93
Coris's Avatar
Oppo Sonica DAC
Well, of course there are solutions to fix this. Going into the firmware it may be a tremendous work... And I am not quite familiar with such things. And in the end one should flash the custom firmware to make it work this fix...
However, it works very well the Oppo`s handicapped ESS9038Pro chips, with only two paralleled channels... If they will come back in business, they may supposedly do things better...
Old 8th November 2018, 10:55 AM   #94
Coris's Avatar
Oppo Sonica DAC
Default My fully upgraded Sonica...
New and fully linear power supply, clock board battery powered, improved DAC power system, and the fully differential (OPA1632 based) output module for both RCA and XLR out (the two available DAC output pairs are tied together). Also some improvements on USB input board. WiFi/Bluetooth module is dismissed in this device.
New clock system it use two SAW oscillators (54Mhz divided for 27Mhz digital clock, and 100Mhz clock for DAC chip.
Very surprisingly the clock system upgrade it is decisive for the final touch in sound quality improvement. I did it this clock replacement in the end, after all upgrades it were in place. Lifting in sound quality after replacing the DAC oscillator, it is obvious.
How it sound all this? Over all expectations...
P.S. The picture hereby it was taken with the device in function. Therefore are placed the small heatsinks on the LPS regulators. Else, the LPS heatsink it will be the cover of the enclosure (thermal contact by thermal pads).
Old 10th November 2018, 02:06 PM   #95
beeppeep61 is offline beeppeep61  Italy
Hi Coris, having already modified the power supplies with low noise modules, I'm very interested in your differential output module XLR-RCA. Are you able to sell (and at what price) this module in assembly kit or preassembled ?? Can you please anticipate an assembly scheme with the modifications to be performed on the SONICA ?? Thank you so much
Old 10th November 2018, 03:55 PM   #96
Coris's Avatar
Oppo Sonica DAC
You have a PM.
Old 27th November 2018, 10:37 PM   #97
Coris's Avatar
Oppo Sonica DAC
My new regulators for +/-12v rails on 105/205 (based on TPS7A)...
Old 28th November 2018, 12:04 PM   #98
dtossan is offline dtossan  Canada
Default TPS7A super low noise regulators
Haha! Very nice Coris. How does it sound?
I see you changed the caps too. What values?
Did you change the bridges to Schottkeys?
Denis
Old 28th November 2018, 02:19 PM   #99
Coris's Avatar
Oppo Sonica DAC
Denis
Ups! I see now that my post above it is in wrong place. It should be on the players thread...As I cannot delete it, I will put it again in the right place. So, I suggest we continue there the discussion on this subject...
Here we shall continue on Sonica subject...
Old 31st December 2018, 11:10 PM   #100
academia50 is offline academia50  Argentina
Here I see great level of knowledge !
So I think you can clarify a simple doubt (I'm crossing my fingers for the answer to be yes)
For some reason that I do not know, the access password through the smart phone is not recognized by the device.
(It's written on a piece of paper, so I do not think it's the wrong password)
I have tried restoring factory settings, but it did not work.
Is there a way to recover the password or to enter a new one ?
Thank you in advance and Happy New Year !
Oppo Sonica DACHide this!Advertise here!
Need hlep with diy dac which perform very well then oppo 105 Leimahmood Digital Line Level 1 24th July 2016 12:16 PM
buffaro2 DAC for OPPO 103(D) blu ray player Jae Hong Lee Twisted Pear 1 17th May 2016 10:29 AM
OPPO as USB DAC? Thatch_Ear Digital Line Level 5 29th March 2016 05:27 AM
OPPO 93 and OPPO 95 - A warning. sandyK Digital Source 3 26th January 2012 07:53 AM
oppo bdp 83 DAC signals ivory Digital Source 0 24th April 2010 05:56 PM
Copyright ©1999-2019 diyAudio
