SA9023+ES9023 USB decoder 24bit/96KHz USB DAC WLX
Old 13th December 2016, 09:22 PM   #1
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default SA9023+ES9023 USB decoder 24bit/96KHz USB DAC WLX
I recently bought one of these off ebay.
When it arrived Windows wasn't having it and came up with an error.
I then figured out it needed an ASIO driver and it worked fine.
Then after a while the audio started dropping out.
I fixed that with a shorter USB lead wit ha filter on it.
Then the pc started having problems with a message saying audio was taking up too much of the resources.
Then the pc itself started locking up and had to be hard reset to get it going again.
So I uninstalled the DAC and the pc is fine now.
Does anyone know a fix for this problem ?
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 13th December 2016, 10:02 PM   #2
CharlieLaub is offline CharlieLaub  United States
Hmm, that sounds a bit vexing. I do have a couple of these, which I have used on and off with Raspberry Pis. I discovered that they seem to sink a lot of power (I think mostly when first connecting to the device) and after I enabled a "high current USB mode" for the Pi's USB bus there were no further problems.
I have also used this on my Windows 8.1 PC a few times and never had any sort of problem. It just worked out of the box when I plugged it in, no ASIO driver required.
Perhaps you got one with a fake SA9023 chip?
I sourced mine from seller "pinshuche" and this seems to be a reliable and reputable seller, based on my interactions over a couple of purchases I have made from them.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 13th December 2016, 11:16 PM   #3
It was cheap only 23 GBP
I found a USB port super charger app and have installed that.
The DAC appears to be running ok at the moment.
Old 13th December 2016, 11:55 PM   #4
I read the spec again for the USB DAC and it only works into 32 ohm headphones.
I am driving an 8 ohm speaker so it could be its not getting enough power.
I suspect the MSI super charger is giving it the extra current it needs and that why everything seems fine now.
Old 14th December 2016, 12:30 AM   #5
Whaaa? You are driving a loudspeaker driver directly with a DAC??? That use is really way outside the specs for the chip...
Old 14th December 2016, 01:07 AM   #6
Its got a headphone driver after the DAC.
SA9023+ES9023 USB decoder 24bit/96KHz USB DAC WLXHide this!Advertise here!
Drivers for Weiliang XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K goodguy2007 Digital Source 1 5th June 2016 06:05 AM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 06:15 PM
Another cheap dac, SA9027 + ES9023 24BIT/96KHZ Asynchronous USB DAC impuls60 Digital Line Level 16 9th August 2015 06:32 AM
Jitters numbers of this te7022-24bit-96khz-usb-to-coaxial-converter ? gaetan8888 Digital Source 9 3rd May 2013 01:51 AM
USB to 24bit/96KHz edpgc Digital Source 8 21st November 2004 01:40 PM
Copyright ©1999-2019 diyAudio
