Replacing caps in a mini USB DAC
Old 11th December 2016, 10:43 PM   #11
kevinkr's Avatar
Moving to the appropriate forum which is Digital Line Level.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 12th December 2016, 10:00 AM   #12
DF96 is offline DF96  England
Don't start out in audio by believing all the myths. Change components if they are faulty or unreliable. If the sound is wrong change the circuit, to a better circuit. If the sound is fine, why change anything? Would you change your car or your house just because someone you have never met (and know nothing about told) you to?
Old 14th December 2016, 01:03 AM   #13
answerawake is offline answerawake
Yea I have learned after reading that the 2704 is a tad outdated. Doh! Well it would be interesting as a first step to see what happens after the components are changed. It is the first step in a long road of learning.
Old 14th December 2016, 01:05 AM   #14
DF96 how can I know if the sound is wrong or not? Best I can do is try it and see if anything changes. It is up to me to decide if it sounds better, worse or the same.
Old 14th December 2016, 09:43 AM   #15
You need to understand that most component 'upgrades' do nothing, some may make a minor improvement (if the original circuit used poor quality or inappropriate items), while some may cause significant degradation (if the new component, however expensive, is in fact inferior). You don't start on "a long road of learning" by swallowing myths. For many DIYers, component 'upgrades' are done simply because they don't know enough to do anything useful but at least they have learned how to solder (and de-solder); when all you have is a hammer, all problems look like a nail. Those who can't solder just swap cables - an even bigger waste of time.
Why not start your long road by doing some real learning? Not about components, but about circuits.
Old 14th December 2016, 11:21 AM   #16
batteryman is offline batteryman  United Kingdom
+1
Only change something if there is reasonable evidence and feedback from others that the change is of benefit.
The HIFI press have a lot to answer for when it come to cables and sound quality. It beggars belief that paying 60 for a fancy AC mains lead (eg teflon insulated, silver plated, screened cable) produces an audible benefit.
Its the old story ' more money than sense'.
Old 14th December 2016, 12:39 PM   #17
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
While you are being right about circuits being most important it is also now quite normal that inferior parts were used as these were cheapest. Also fake parts are used. Especially electrolytic caps are often garbage. So changing parts is not a waste of time with cheap Ebay and Aliexpress stuff. You could debate if it is not wiser and cheaper to buy a A branded device straight away
I think most of us have replaced caps for better quality (like MKS for MKP) and noticed a difference. Also changing opamps can make a difference when chosen wisely. You are not in the camp "parts and cables don't make a difference" do you ? If so I dare to say "every amplifier that measures the same sounds the same"
It's only audio. Member of the non modular PCB design committee
Old 15th December 2016, 09:23 AM   #18
MKS and MKP are different dielectrics, so the issue is not quality but appropriateness for the application (coupling, decoupling, filter?). I am unconvinced about opamp rolling, unless the original opamp was inappropriate or so old that modern ones have lower noise. It is easy to make a circuit sound different by swapping parts, but harder to actually improve the performance.
Parts (if appropriate) make little difference. Cables (unless faulty, such as many DIY cables and some high-end cable) make no difference to well-engineered equipment; cable fussiness is a sign of poor equipment design.
Amplifiers which measure the same (including frequency response and output impedance) appear to be indistinguishable when used unsighted below clipping. I have not done the experiments myself, but others have. I have no reason at present to doubt these results.
I guess that makes me guilty as charged.
Old 15th December 2016, 02:46 PM   #19
jean-paul's Avatar
Hi I think I was 12 or 13 when I discovered film caps sounded different. MKP had a better sound character than MKS and MKC. I replaced electrolytic caps for MKT and found them to sound better. I replaced noisy opamps for better ones with JFET inputs in gear. Could be noticed by anyone that was there....
Parts do make a difference and this can be checked in a few minutes. I guess you just skipped this and don't want to try it out.
Old 15th December 2016, 03:10 PM   #20
You were obviously an early starter. At 12 or 13 I was still learning Ohm's Law and other physics relating to electronics. Some people try to skip this.
Using the wrong parts can certainly make a difference. Swapping one appropriate part for another appropriate part can usually only be heard when the listener knows that a swap has taken place.
Replacing caps in a mini USB DACHide this!Advertise here!
PCM5102 Mini USB DAC Schematic and layout critique miniengineer Digital Line Level 2 17th February 2015 01:04 PM
NuForce Icon UDAC-2 mini USB DAC/ headphone amplifier hatrack71 Swap Meet 0 8th April 2013 12:17 AM
Muse Mini USB DAC or Converter? whaleman Digital Source 2 4th June 2011 07:45 PM
AUNE - MINI USB DAC/Headphone amp kmtang Digital Source 23 9th September 2010 06:25 PM
Wanted: USB board for Apogee mini-DAC Puggie Swap Meet 0 3rd April 2007 10:46 AM
Copyright ©1999-2019 diyAudio
