Hello, i am seeking a suggestion for best chip to use.
I want to expirement with different filters (low pass, highpass, band stop/pass) audio filtering of a analouge signal.
Since i am not interrested in the normal frequency range (20-20 kHz), i want to be able to setup different experimental filtering in the frequency range 15 kHz to 80 kHz.
Is there a eazy to use chip, withh audio in and audio out, and where i can program the chip (not complex DSP algotitms), but from external pins on the chip, i was thinking of something like the MAX260 universal active filter chip, or is there a better ons chip solution?
Thank you.
Thank you.
