Building with the Soekris dam1121
Thread Tools
Old 6th October 2021, 02:37 PM   #981
dewdrop is offline dewdrop  Singapore
Very neatly done!
Old 21st November 2021, 12:03 PM   #982
bmxmen is offline bmxmen
Hello i have a problem with my two 1121 dam connectec to have full balanced ouput. When my i2s sourse was a amanero 384 combo everythink works fine. I have change amanero for jl sounds i2soverusb i have a problem. But let me start what situation is with no i2s source connected to master 1121. When i power on it leds blinkg, after 2 second slave led power off, master led is stil blinking, im tninking that slave have connection lock with master, and master is waiting for i2s signal. But when i connect i2s source(i2soverusb jl) to master 1121,the situation is difrent. slave led blinking, master led ale blinkg for couple seconds and power of for 3 second,andnsame blinking for couple sec and off. What is going on? very thanks for help.
Old 25th November 2021, 07:17 AM   #983
Hello did any one has try optical in? In 2x 1121 balanced mode?i have diyinhk optical reciver connected to 3.3v and to spidif in on master 1121 but it not detect it..
Old 25th November 2021, 07:57 AM   #984
TNT is offline TNT  Sweden
Yes I run a board with optical in and balanced out mode and it works. I just used a Toshiba TORX147L TORX147 15Mbps Fiber Optical Receiver 3 pin x 1pc | eBay and a 3,3v stab.
You listen to a system, not a bunch of components.
Old 25th November 2021, 08:31 AM   #985
Have you instaled leds on boards?
Old 25th November 2021, 08:57 AM   #986
Please tell me, did your config and connecition looks same as picture?
Old 25th November 2021, 09:04 AM   #987
They where standalone boards - i.e. without that board sync configuration i.e. 2 separate mono configs used as stereo via an active Toslink "duplicator" that I built. As I recall it it was just to connect out form the TORX to the input pin. I did feed the TORX 3,3v via a LT stab.
Old 25th November 2021, 09:08 AM   #988
Check out post #70 ->
Old 25th November 2021, 06:31 PM   #989
minoas is offline minoas  Greece
good evening and sorry for the intervention
Does somebody knows how to connect Soekris dam1021 to Philips CD PRO2 using I2S interface
thank you
  Reply to this post
Building with the Soekris dam1121Hide this!Advertise here!
Thread Tools
Soekris' DAC implementations Eldam Digital Line Level 1285 27th May 2020 10:42 AM
Output stage for the Soekris R2R robertrowett Digital Line Level 122 11th February 2017 11:38 AM
Sorry, need help again...Soekris Dac lock Green77 Digital Line Level 0 8th December 2015 06:49 PM
looking for soekris r2r dac fabrice63 Swap Meet 2 1st June 2015 10:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
