Building with the Soekris dam1121
TNT
Joined 2003
Yes 640 ohm. I did one comparison when I got my first DAC and never looked back. A few variations between a couple of k to 50k. According to the designer, the only thing that happens is that the output level is decreased - no other impact. You could short circuit the output without hurting the electronics as I understand it.
I have another question concerning the Atmega-controlled volume: the dam1121 manual says that the COM_RXD, COM_TXD ports work at 3.3V digital level. The Atmega TXD/RXD, on the other hand, operate at 5V level. How do you solve this? Can simply the insertion, say, 2k2 resistors in the RXD/TXD lines save the day? Or do I need to include a proper level shifter?
Thanks,
Miklos
