Building with the Soekris dam1121
Old 16th February 2019, 12:47 PM   #551
dewdrop is offline dewdrop  Singapore
Originally Posted by derekr View Post
Have you grounded RPI to 1121?
Yes I did
Ed
Old 16th February 2019, 02:14 PM   #552
intense-tavda is offline intense-tavda  Netherlands
Hi There!
I got my boards together, I put the comperator board on the spdif point 6 from J2, connected the cd drive and no sound, only the led blinks 10 times and than it stops. Any idea why there is no sound?
Old 16th February 2019, 08:24 PM   #553
derekr is offline derekr  Barbados
Originally Posted by dewdrop View Post
Yes I did
Hmm....then I guess the usual steps - can you confirm (via another DAC) that your RPI is working via its i2s out? Are you measuring plus and minus 5V on the analog power pins on the 1121? And plus 5V on both digital power pins?
Assuming your strapping resistors are all good and going to ground (one or multiple grounds? Not that it should matter but double check them) I’d hook up a terminal program and check you’re getting the correct readout on power up.
Doesn’t hurt to connect the PWR_LED as well. Finally, what’s downstream? Is that amp/speakers or whatever working with output from another DAC?
Good luck.
Old 17th February 2019, 07:28 AM   #554
@derekr, I appreciate you trying to help.
I have checked the +/-5V rails and they are all good.
Double checked on:
Raspberry Pi J12 <-> I2S BCLK_I
Raspberry Pi J35 <-> I2S LRCK_I
Raspberry Pi J40 <-> I2S DAT_I
I have added the PWR_LED and it remains unlocked even when there is content playing so it has nothing to do with the downstream equipment.
The next thing is to swap out the Raspberry Pi board with one that definitely works as well as to setup the terminal program to see the board status.
Ed
Old 17th February 2019, 07:55 AM   #555
bambadoo is offline bambadoo  Norway
How long cables? And use 3 gnd wires.. i2s is quite difficult in this regard
Old 17th February 2019, 09:23 AM   #556
Default Success! Well kind of...
Thanks guys for all the suggestion. Finally gotten the 1121 to play music on 96/24 FLAC and WAV files. Yah!
The culprit was the Raspberry Pi/Moode software. I swapped them wholesale from a working setup. I will investigate if its the board or the software later.
I have a new issue. I tried to use the MoOde 4.4 software to play DSD over DoP , although the LED shows that a locked status, there isn't any music. When I turned off the DoP setting, even though the LED blinks in the unlocked state, there is music but it stutters.
Anyone has experienced this before?
Ed
Old 17th February 2019, 04:20 PM   #557
Turn off SoX resampling in Moode.
Old 17th February 2019, 10:30 PM   #558
It is already disabled.
But you got me tinkering around the SoX settings and I found that with the multi-threading with SoX enabled and 32 bit/96kHz got it to play DSD. Thanks!
Ed
Old 25th February 2019, 08:48 PM   #559
Arek8 is offline Arek8
I'm back with balanced 2xdam1121. It is working with amanero usb but it does not work with spdif input. I have connected coaxial RCA input straight to spdif input on master board. I see in the soekris manual once it should be connected to SPDIF pin without comparator MAX3280 and next schematic RCA to RXD pin by MAX3280. So what is right? I would like to use coaxial input from cd player.
Old 28th February 2019, 04:00 PM   #560
Hi Arek8!
I got the same question a view posts back, but did not get an answer. Maybe they wil answer it now. I hope so, so we can get further on, and enjoy the music.
Building with the Soekris dam1121Hide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1112 11th January 2019 05:35 AM
Output stage for the Soekris R2R robertrowett Digital Line Level 122 11th February 2017 10:38 AM
Sorry, need help again...Soekris Dac lock Green77 Digital Line Level 0 8th December 2015 05:49 PM
looking for soekris r2r dac fabrice63 Swap Meet 2 1st June 2015 09:50 AM
Copyright ©1999-2019 diyAudio
