Hello,
I got an answer from Brian ( Belleson). Have to see if i can modify the power supply for the motherboard without having to mess everything up. Because the holes in dac board are used for mounting. I can use 2 holes on the big board to support a metal strip that will serve to mount some small parts. Have to do it in such a way that taking the dddac out from the chassis will not be to much of a hassle. greetings, Eduard
